04-24-2018, 03:31 PM | #1 |
Gasket Cement
What's the best gasket cement to use on heads, oil pans, water pumps,etc.
I need to buy some new stuff as all of mine is too old to consider using. Peter |
04-24-2018, 03:57 PM | #2 |
Re: Gasket Cement
Just grease on water pump gaskets. G.M.
www.fordcollector.com |
04-24-2018, 04:20 PM | #3 |
Re: Gasket Cement
Grease on the water pumps, silicone on the oil pan gasket and on the head gaskets, it depends on the gasket material your using.......Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
04-24-2018, 05:13 PM | #4 |
Re: Gasket Cement
# 2 permatex
Bruce
Works good Lasts long time |
04-24-2018, 05:44 PM | #5 |
Re: Gasket Cement
I don't use anything on the gaskets. Grease would be OK as it would keep the gasket from sticking if you have to remove something.
04-24-2018, 11:18 PM | #6 | |
Re: Gasket Cement
That's all I ever use. Just grease. Saves scraping off a lot of cooked on gasket or cement or both.
04-25-2018, 05:51 AM | #7 |
Re: Gasket Cement
That's really interesting how many of you just use grease. I never would have guessed that.
Thanks for your help. Peter |
04-25-2018, 08:17 AM | #8 |
Re: Gasket Cement
Vote #4 for grease. If you consistently need something more, you should re-think the thoroughness of your surface preparation.
04-25-2018, 08:34 AM | #9 |
Re: Gasket Cement
Likewise, that's all I use the gaskets located between properly prepared mating surfaces.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 04-25-2018 at 02:02 PM. |
04-25-2018, 09:33 AM | #10 |
Re: Gasket Cement
After scraping cement off the surfaces of some thing "that I would never ever have to remove", I now use grease on all gaskets.
04-25-2018, 01:12 PM | #11 |
Re: Gasket Cement
Just Grease on them all.
04-26-2018, 06:28 AM | #12 |
Re: Gasket Cement
We paint assembly lube with the acid brush. This lube is kind of stickey.
04-26-2018, 07:35 AM | #13 |
Re: Gasket Cement
Grease slathered on all surfaces except exhaust manifold. Jack E/NJ
04-26-2018, 08:36 AM | #14 |
Re: Gasket Cement
Looks like most of us here are Greasers
04-26-2018, 09:05 AM | #15 |
Re: Gasket Cement
I like to use copper spray on copper head gaskets, everything else grease, unless I'm dealing with a very porous surface or a poor alignment which a decision would need to be made on repairing that issue if possible. I never reuse head gaskets. JMHO
04-29-2018, 02:47 AM | #16 |
Re: Gasket Cement
for what its worth i recon you cant go past a stuff from loctite called 515 looks like plum jam wont set unless under pressure [bolted up] has the ability to fill most minor imperfections can be used with or without gaskets doesn't clog oil galleries and best of all if you have to separate parts at some stage you wont need a stick of dynamite and a tyre lever to do so but all things have their limits and its no good for heads or exhausts being a heavy mechanic by trade it doesn't take long to work out what works
04-29-2018, 10:07 AM | #17 |
Re: Gasket Cement
Just curious since I have never used grease on gaskets before, is there any specific grease ie: grade, low temp, graphite, ect recommended, or does it matter? Bill
04-29-2018, 10:46 AM | #18 |
Re: Gasket Cement
From the HVAC side of life we typically us a copper base never-seaze, I have always used this on bolts and any gaskets that are of that thin brown type material.
05-01-2018, 05:04 AM | #19 |
Re: Gasket Cement
I just use a light rub of wheel bearing grease on the gaskets. As stated, easier than scraping...Chap
05-01-2018, 08:29 AM | #20 |
Re: Gasket Cement
For water, oil, and vacuum with paper or cork gaskets I use Yamabond #4, made by Yamaha. It will maintain a seal under heat, pressure, resistant to oil, gas, no hardening, and very easy to disassemble and clean-up. Using grease, which is oil and thickeners, on an oil pan gasket, for example, means you are relying on the thickeners for their sealing properties.
