08-02-2017, 09:09 PM | #1 |
Trying to figure out if I have a High Compression Head
Hi All,
I have a 1930 Coupe with a fairly fresh engine. It was apparently "really" gone thru. Ungortunatly I did not get the paperwork re. this work when I got the car last summer. And it's not available - I checked. My question is: How can I tell if it's got a High Compression Head - will a simple compression test tell me? What should the "stock" compression be on a fresh engine w. a OEM head? TIA ... again Chris Union, ME |
08-02-2017, 09:45 PM | #2 |
Re: Trying to figure out if I have a High Compression Head
Fresh, stock engine ~ 65psig. Hi Compression... Higher. Depends on the ratio.
08-02-2017, 10:15 PM | #3 |
I have a similar issue. I have no history on a great engine in a coupe i bought. The owner got it from his dad and can only remember years ago he helped put a "rebuilt" engine in the car. It does have a police head with the large "d" on it toward the front half of the head. 94 psi in all four cylinders. Wish i knew where it came from and if they still do engines. This one is great, but no idea what is inside it.
08-02-2017, 10:18 PM | #4 | |
www.whidbeymodelaclub.com |
08-03-2017, 04:16 PM | #5 |
Do a compression check. Take the average value you get and divide by 15. That will give you a close approximation of your compression ratio. Stock heads have a 4.2 compression ratio.
AL in NY |
08-03-2017, 04:33 PM | #6 |
Terry |
08-03-2017, 07:01 PM | #7 |
Using Terry's formula I get 88.2 lbs. for my engine. Using Al in NY i get 6.7 compression ratio. Somethings wrong here... Snyder said that head is 6.0:1 I'm getting 100 lbs. in all 4 holes.
08-03-2017, 07:34 PM | #8 |
i get 67 on my stock head. no idea how fresh. I think stock can be up into the 80s. over that high comp in various state of wear.
08-03-2017, 07:54 PM | #9 | |
Dennis, where you hang your hat in SoCal? |
08-03-2017, 08:08 PM | #10 |
Also, should compression be done on a cold, warm or hot engine?
08-03-2017, 09:47 PM | #11 |
08-03-2017, 11:16 PM | #12 |
I always do them cold because when your engine wont run you wont be able to warm it up. So at that time you will be comparing apples to apples. also I always hear people say do the test with throttle open but I see no difference on the gauge.
08-03-2017, 11:33 PM | #13 |
08-04-2017, 12:09 AM | #14 |
Sadly my compression tester is too small for my head. I guess I'll have to break the porcelain out of an old spark plug to test it.
I'm off the 405 in the SF Valley.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
08-04-2017, 12:45 AM | #15 | |
http://www.snydersantiqueauto.com/spark-plug-adapters My Snap-On compression tester has the Model A size included. |
08-04-2017, 01:09 AM | #16 | |
08-04-2017, 07:57 AM | #17 |
Yep, it never made a difference for me either.
08-04-2017, 10:56 AM | #18 | |
But the one from Snyder's is threaded for a 14mm plug and my compression tester screws right in. Unless you have a el cheapo gauge with just a rubber tip, then that is a moot point. |
08-04-2017, 02:07 PM | #19 |
I have been using my rubber tipped El Cheapo for over 50 years.
08-04-2017, 04:18 PM | #20 |
I used one of the o-ringed ends that comes with the cheap kits. had to hold it with two hand and have a helper run the starter.
08-05-2017, 08:04 AM | #21 |
with the formula above I got 8.4-1 on my 7-1 head . 126#/cylinder
V4f |
08-05-2017, 09:00 AM | #22 |
Dennis, It makes my head hurt to try to figure out these numbers! So I asked the question, How much did the compression ration increase by boring out a block .040? Someone younger and more mathematically more adept than I am, came up with the figure of approximately (IIRC) .047. So a mod. A bore of 3 7/8, bored out .040 increases the CR by .047 or it goes from 4.2 to 4.247. It ain't much! But one thing to recall is it is not the same no matter what the diameter. As the dia. increases, the amount of stock removed increases.
Terry |
