Old 12-01-2019, 09:18 AM   #1
ericr
ericr's Avatar
Default Do You Guys Constantly Re-touch Wheel Spokes?
were the original lug nuts on the wheels slightly wider than repros, as it seems to me the wheels always get scratched using the crank tool, which is a sloppy fit.
Do you guys use a regular socket to take wheels off?
I once saw a suggestion to wrap foam around the crank tool but in any event, how do you guys avoid marring the spokes and the wheel hub, especially on colored wheels.
ericr is offline   Reply With Quote
Old 12-01-2019, 09:29 AM   #2
GPierce
GPierce's Avatar
Default Re: Do You Guys Constantly Re-touch Wheel Spokes?
I use a regular socket on a short extension wrapped in duct tape to protect the spokes and attached to a long Craftsman 1/2” ratchet. It also facilitates finishing up with a torque wrench. Yes I know torque wrenches weren’t used at Ford or anywhere else during the Model A period.
GPierce is offline   Reply With Quote
Old 12-01-2019, 10:07 AM   #3
taffrail
taffrail's Avatar
A little tape on the bar of a 4- way lug wrench and a rubber bumper cut to fit inside the socket helps to keep it off the hub works well.
taffrail is offline   Reply With Quote
Old 12-01-2019, 10:09 AM   #4
fried okra
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
GPierce.....what torque value do you use for tightening the wheel lug nuts?
fried okra
fried okra is offline   Reply With Quote
Old 12-01-2019, 10:53 AM   #5
Ray in La Mesa
I fill my lug wrench, socket, hand crank with newspaper and dip it in rubber handle dip about 5"-6" 3-4 times and let it dry. cut end open with a utility knife but leave the leading edge covered, tadaaaa, no more scratched wheels. I have a star lug wrench so the red handle dip shows which end to use.
Ray in La Mesa is online now   Reply With Quote
Old 12-01-2019, 11:09 AM   #6
mike657894
mike657894's Avatar
I just bash the paint all to hell. But this has got me thinking and I will be glueing or wire tieing on a small piece of thin black rubber.
mike657894 is offline   Reply With Quote
Old 12-01-2019, 06:22 PM   #7
marty in Ohio
marty in Ohio's Avatar
I cut off a socket so that it holds the lug nut but is not so deep that it touches the rim. This fits on a 6" extension with a foam sleeve on it. Works for me.
Marty
marty in Ohio is offline   Reply With Quote
Old 12-01-2019, 08:08 PM   #8
TerryO
TerryO's Avatar
I have a dedicated socket and 6" extension that I covered with heat shrink tubing. I used about 6" and let it cover socket and extension which also holds it together. This protects the inner part of the wheel and also the spokes...
TerryO
TerryO is offline   Reply With Quote
Old 12-01-2019, 08:24 PM   #9
Y-Blockhead
Y-Blockhead's Avatar
2X with the shrink tubing like TerryO. Since I have chrome lug nuts I also use nut protectors.
Old 12-01-2019, 09:16 PM   #10
Synchro909
Synchro909's Avatar
Is that why you walk funny!!!
Old 12-02-2019, 12:03 AM   #11
Y-Blockhead
HAH!! Could be. Ya wanna check them out?
But joking aside I meant like these https://www.macsautoparts.com/ford_m...es-365045.html Won't protect your paint but they protect your nuts!!
Old 12-02-2019, 06:23 AM   #12
ryanheacox
ryanheacox's Avatar
fried okra
Not GPierce, but I usually torque lug nuts to 55lb-ft
Old 12-02-2019, 08:33 AM   #13
Bob Bidonde
Bob Bidonde's Avatar
Painted wheels need touch ups often, but powder coated wheels do not.
Bob Bidonde
Old 12-02-2019, 09:19 AM   #14
ericr
ericr's Avatar
TerryO
how did you cut a socket, aren't they hardened?
Old 12-02-2019, 10:55 AM   #15
Jeff/Illinois
Jeff/Illinois's Avatar
That's funny!!
Old 12-02-2019, 11:30 AM   #16
katy
katy's Avatar
You could use a disc grinder w/a cutting disc.
Old 12-02-2019, 11:31 AM   #17
katy
katy's Avatar
Deleted, duplicate post.
Old 12-02-2019, 11:41 AM   #18
Dick Steinkamp
Dick Steinkamp's Avatar
Non-marring socket
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 12-02-2019, 12:24 PM   #19
GPierce
GPierce's Avatar
fried okra
55 ft-lbs
Old 12-02-2019, 12:27 PM   #20
GPierce
GPierce's Avatar
Duplicate post
