Old 09-08-2018, 05:26 PM   #1
Ken B
Ken B's Avatar
Default Curious of your preference
I was wondering what everyone's preference is regarding using the foot pedal accelerator or the lever on the steering column. I tend to use the foot pedal from a stop to get up to speed then switch to using the lever on the steering column. What are some other preferences. Was Henry Ford reluctant to give up the steering column accelerator lever used on the Model Ts?
Ken B is offline   Reply With Quote
Old 09-08-2018, 05:35 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Curious of your preference
Pedal
www.whidbeymodelaclub.com
Old 09-08-2018, 05:59 PM   #3
redmodelt
redmodelt's Avatar
Most of the A's I have worked on, the detentes are worn to the point of no use and if spring is good on the bracket and weak on the lever shaft, the lever works it way back up. Foot feed
Old 09-08-2018, 06:04 PM   #4
WHN
Use the foot pedal for driving. Use the steering column lever for starting only.
Old 09-08-2018, 06:05 PM   #5
GerryAllen
pedal / foot feed
GerryAllen is offline   Reply With Quote
Old 09-08-2018, 06:31 PM   #6
Bob-A
Bob-A's Avatar
Thumbs up Re: Curious of your preference
Mostly pedal, but if the road is nice. I might put the 'ol buggy on cruise control and use the throttle lever.
Bob-A
Bob-A is offline   Reply With Quote
Old 09-08-2018, 06:36 PM   #7
FordTudor1931
FordTudor1931's Avatar
Pedal!
FordTudor1931 is offline   Reply With Quote
Old 09-08-2018, 07:49 PM   #8
marty in Ohio
marty in Ohio's Avatar
Using the lever for driving looks like trouble to me!
Marty
marty in Ohio is offline   Reply With Quote
Old 09-08-2018, 07:54 PM   #9
eagle
eagle's Avatar
I use the hand throttle for cruising. Also use it to bring the RPM up a bit when its cold, then drop it again when I take off. Lower RPM makes for smoother shifting.
Old 09-08-2018, 07:54 PM   #10
Jeff P. / MN
Jeff P. / MN's Avatar
I’m with Bob-A. A little cruise control on the flatlands is nice...give the ol’ right foot a rest.
Jeff P./MN
1913 Model T Runabout
1926 Model T Sport Touring
1948 Chrysler New Yorker
Jeff P. / MN is offline   Reply With Quote
Old 09-08-2018, 10:28 PM   #11
Fordfan29
I agree with Marty in Ohio. In modern cars there is an automatic throttle cancelation if you touch the brakes. Not so in our 90 year old cars. Accidents happen quickly & unexpectedly. No time to be playing with a hand throttle.
I use only the pedal except for while the car may be sitting in one place.
Fordfan29 is offline   Reply With Quote
Old 09-08-2018, 10:34 PM   #12
Mike V. Florida
Mike V. Florida's Avatar
Could be, after years of using the column throttle it might have been easier for the T drivers.
Old 09-08-2018, 11:16 PM   #13
vonheine
The throttle on the steering column of a Model A Ford is really there so that the engine can be used as a stationary power plant. AA trucks and all versions of A cars share the same engine and controls. A AA truck with a power takeoff arranged to run a saw, a cement mixer, a water pump, or a generator would be very difficult to control if the column lever was not there. Henry made them all the same for ease of production. I prefer the foot pedal unless I am on a long trip with low risk of cruising interruptions. Then I use the column throttle as a form of ancient “Cruise Control.” I also use the throttle lever during a cold start. It serves as a fast idle until it runs smoothly. I prefer to drive with the lever up for normal driving an use my foot.
vonheine is offline   Reply With Quote
Old 09-09-2018, 06:30 AM   #14
woofa.express
woofa.express's Avatar
It's a personal choice. use what you are comfortable with.
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 09-09-2018, 09:48 AM   #15
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Since I own several Model-Ts and brass-era vehicles that only have a hand throttle, I enjoy using the hand throttle on a Model-A once I am in high gear. I do it simply to break the boredom while I am driving. Ford originally incorporated this feature because of the familiarity of his customers with the throttle lever. I think it would be a fair statement to say that today, most Model-T drivers can safely & efficiently drive a Model-A however most Model-A drivers cannot safely drive a Model-T. It likely boils down to familiarity.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 09-09-2018, 10:20 AM   #16
30 Closed Cab PU
Usually not flat enough here to use as a cruise control.
Old 09-09-2018, 10:36 AM   #17
JBill
Same for me.
JBill is offline   Reply With Quote
Old 09-09-2018, 02:04 PM   #18
40 Deluxe
Hmmm, I don't think so. More is needed. There is too much variation in RPM between loaded and unloaded conditions. For example, running as saw. It takes very little throttle to run the saw at operating RPM without a load. Start sawing into an oak log and you may need full throttle to avoid killing the engine. Finish the cut at wide open throttle, and the engine will overspeed and soon kick out a rod. A load-sensing governor is needed to control RPM. I don't think Ford would put a hand throttle on millions of A's just for a relatively few industrial/farm uses.
40 Deluxe is online now   Reply With Quote
Old 09-09-2018, 03:03 PM   #19
updraught
updraught's Avatar
On rough roads with sprung seats (especially RHD) the driver bounces goes up and off the pedal, and comes down onto the pedal, making rough roads much worse. Some say kangaroo juice.
The hand throttle keeps the speed constant. Good for driving down creek beds.
Don't ask how I know.
updraught is offline   Reply With Quote
Old 09-10-2018, 12:29 PM   #20
burner31
burner31's Avatar
Pedal
Keith
Shawnee OK
'31 SW 160-B
