Old 04-06-2015, 08:42 PM   #1
oldbike99
oldbike99's Avatar
Default 1931 Coupe wiring harness routing
Can anyone tell me if the tail light/brake switch harness is routed over or under the brake cross shaft? Thank you
oldbike99 is offline   Reply With Quote
Old 04-06-2015, 08:54 PM   #2
160B
160B's Avatar
Default Re: 1931 Coupe wiring harness routing
Mine goes over the brake cross shaft.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 04-06-2015, 09:12 PM   #3
160B
160B's Avatar
Here is the service bulletin page 215.
Old 11-17-2019, 12:15 PM   #4
37 Coupe
37 Coupe's Avatar
when the wire leaves the light switch to the rear stop light switch and tailamps is it running insde the frame channel .on top or on bottom? I have been searching all morning ,then make my attempt in the garage and come back to search some more.This picture above helps some but not enough. It looks to me it has to go bottom frame when it leaves but somewhere it goes inside frame?
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 11-17-2019, 01:13 PM   #5
1930 coupe
Someone posted these pictures many years ago of original factory installed wiring on a low mileage car
1930 coupe is offline   Reply With Quote
Old 11-17-2019, 04:45 PM   #6
37 Coupe
37 Coupe's Avatar
Thank you,figured it out now.
Old 11-17-2019, 08:03 PM   #7
taffrail
taffrail's Avatar
Great pictures. I have a Pick-up with the wire under the motor mount and a Tudor with the wire over, which is correct ?
taffrail is offline   Reply With Quote
Old 11-17-2019, 08:35 PM   #8
37 Coupe
37 Coupe's Avatar
I think according to the above pictures it runs below the motor mount.That is how I did mine today and I used quite of few frame clips. I have some that are short and they fit the frame very good depth wise.The last ones I got seem to long and stick out a 1/4" instead of snug agaist the lower frame channel.
Old 11-17-2019, 09:42 PM   #9
History
History's Avatar
I'm glad this question was asked. I recently installed a new wire harness and was surprised the wire didn't run all the way to the tail light. I didn't realize there was an extension that goes to the tail light until I asked here.
I still wasn't sure how it should be ran, this thread answered that for me.
Thanks
History is offline   Reply With Quote
