Old 08-06-2019, 06:37 AM   #1
History
History's Avatar
Default Gas tank cap venting?
I assume the gas tank cap is designed to vent from internal pressure and as the gas heats up it expands,,,,,,,,,. I also assume it's designed to let air in to equalize pressure as the gas gets cold and condenses? How could I check my cap before I put gasoline in as my tank is bone dry at the moment? Should I be able to hear air escaping if I pressurized the tank slightly?
I'd like to not have to wonder later.
History is offline   Reply With Quote
Old 08-06-2019, 07:07 AM   #2
kimlinh
Default Re: Gas tank cap venting?
The gas cap is not high tech there is a small hole that vents pressure. Look at your cap. If there is a small hole in the inner cap(caps are made in two pieces) and the hole is not blocked, your good.
kimlinh is offline   Reply With Quote
Old 08-06-2019, 07:09 AM   #3
johnbuckley
johnbuckley's Avatar
warm soapy water around the cap and look for bubbles when slightly pressurizing the tank?. (on some gas caps I haven't been able to see the hole - hidden under a plate?)
Old 08-06-2019, 08:44 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
Blow compressed air through the vent hole in the cap.
Bob Bidonde
Old 08-06-2019, 09:05 AM   #5
Redbird
Redbird's Avatar
Shake the cap!
Redbird is offline   Reply With Quote
Old 08-06-2019, 09:15 AM   #6
40 Deluxe
The cap also has to be vented so air can enter to replace the gas used as you drive, or the carb would soon run dry!
40 Deluxe is online now   Reply With Quote
Old 08-06-2019, 09:53 AM   #7
katy
katy's Avatar
What year is your A?
Old 08-06-2019, 10:29 AM   #8
Aretino
Aretino's Avatar
Had to lay the cap upside down and soak the vent hole with carb cleaner. Then I used compressed air to assure an open vent passage way.
Aretino is offline   Reply With Quote
Old 08-06-2019, 11:20 AM   #9
Jim/GA
Jim/GA's Avatar
The most important first question to ask! The '28-29 caps are pretty reliable; the '30-31 reproductions are a real pain, not venting.
You should never hear pressure escaping when you take a cap off.
It is also easy to accidentally put an unvented radiator cap on the gas tank. Not good.
Jim Cannon
"Have a Model A day!"
Old 08-06-2019, 12:14 PM   #10
History
History's Avatar
I'd bet that's the (main) reason it's vented.
My car is a 30. I put a new gasket on the cap as the old one was almost gone. I believe the gasket is leather?? Cap is as mentioned a two piece part. I can't see a hole anywhere and the part under the cap is a pressed part. I'll look at it closer and see what I discover. I just thought I'd ask as it might help me and others
Old 08-06-2019, 12:36 PM   #11
Tom Endy
Tom Endy's Avatar
30-31 reproduction gas caps are prone to rotating on the single rivet in the center that will block off the vent hole. Snyders sells and Eaton style cap that incorporates two rivets to prevent rotating. See the attached.
Tom Endy
Old 08-06-2019, 12:37 PM   #12
Tom Endy
Tom Endy's Avatar
try again
Old 08-06-2019, 12:58 PM   #13
Purdy Swoft
Purdy Swoft's Avatar
Not showing here .
Old 08-06-2019, 01:59 PM   #14
whirnot
whirnot's Avatar
Light bulb moment!
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 08-06-2019, 04:46 PM   #15
TerryH
TerryH's Avatar
Years ago, Tom Endy fixed my repro gas cap per his attached article.....works great!
TerryH is offline   Reply With Quote
