Old 06-07-2019, 12:34 PM   #1
HS
Default New Radiator, Berg vs Brassworks
I guess I'm going to bite the Bullet and finally replace my old and tired 1928/29 older reproduction radiator. It has been a good one, been across the USA and back but at this point its time for retirement.
I'm looking at two Radiators, Berg's and Brassworks. Both are quality items. The Berg Radiator that I'm looking at is a hefty $795 plus ship&H with Brassworks priced at $645 plus S&H ship, Both are the flat tube with 10 fins per inch-- modern efficient cores. If any you have or had one of these, I would love to see your comments/advice regarding what you think about these two radiators.
Have a Great day,
Hugh
HS is offline   Reply With Quote
Old 06-07-2019, 12:38 PM   #2
CarlG
CarlG's Avatar
Default Re: New Radiator, Berg vs Brassworks
Mine is a '31, from Berg's. Very pleased with it, no fit problems at all.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 06-07-2019, 02:49 PM   #3
Jersey Mike
Jersey Mike's Avatar
I bought a Berg radiator for my 29 Speedster it works great. You'll probably need a 160 deg. thermostat. My ran at about 130-140 deg. without a themostat. Check to see if the Brassworks is 2 or 3 rows of tubes. The 31 I bought for a customer only had 2 rows of tubes. Hope this helps.
Jersey Mike is offline   Reply With Quote
Old 06-07-2019, 03:52 PM   #4
hotrodart
hotrodart's Avatar
My son got one for his '31from Brassworks about 25 years ago.....trouble free.....
hotrodart is offline   Reply With Quote
Old 06-07-2019, 03:58 PM   #5
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Hugh, check your text message.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 06-07-2019, 04:10 PM   #6
john in illinois
john in illinois's Avatar
I have a recored original with an extra row of tubes from Bert’s. Great radiator but people in my club really like Bergs. There are several and all fit and work well. A while back Brassworks had fit problems with necks. Maybe they have it fixed now.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 06-07-2019, 06:38 PM   #7
The Brassworks
The Brassworks's Avatar
Thank goodness. Three rows would have hit your customer's fan in a standard Model A. You get 2.93x's the cooling surface area with each tube because of the elliptical shape e.g. fewer of them gives you more cooling.
The Brassworks is offline   Reply With Quote
Old 06-07-2019, 09:44 PM   #8
Davew
Davew's Avatar
I have a Bergs. Had to use cardboard in front of the radiator this spring to warm it up.
Davew is offline   Reply With Quote
Old 06-07-2019, 11:38 PM   #9
al's28/33
al's28/33's Avatar
Brassworks since 2001, no issues ever! and use a thermostat. Never had one issue with overheating even on 105 degree afternoons......
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 06-07-2019, 11:40 PM   #10
Russ/40
Russ/40's Avatar
I chose the Berg, at the time based on availability. Berg had them on the shelf and Brassworks had 4 week availability. I'm happy I got the Berg. I like the cast brass input output fittings.
Old 06-08-2019, 12:55 AM   #11
pbishop
In 2015, installed a 'Brassworks' in my 1931 Coupe. Had to do a little increase diameter of lower mounting holes. Other than that the radiator fit well and has worked wonderfully. I have a Weber two barrel and can now drive the Model A 'wide-open' at over 65 mph for miles-and-miles and have 'NO' over-heating issues (runs around 175 degrees without coolant - Tampa, FL. summers).
pbishop is offline   Reply With Quote
Old 06-08-2019, 08:17 AM   #12
30 Closed Cab PU
I used a Bergs replacement last winter due to having a problem with an undersized aftermarket 2 row core radiator . Brassworks is the only 2 row I am aware of that is a good working 2 row radiator.
If ordering from Brassworks insure you thoroughly read and and follow all the info on their website. Call them to insure you understand, and ask any questions before ordering. Brassworks, there have been past reports of minor fitment issues, and incorrectly sized inlet/outlets - am unsure if these have been corrected. Some models of Brassworks are made to Ford prints, and can be used on cars being judged.
I went with Bergs, never a report of a problem with them, and wanted something absolutely drop in replaceable, no fitment or mounting modifications needed. So far is working great, but waiting for hot weather to confirm no issue on my recently rebuilt motor.
Old 06-08-2019, 11:29 PM   #13
31a
I have used Brassworkks with no problems run a thermostat
31a is offline   Reply With Quote
Old 06-09-2019, 06:44 AM   #14
HS
Brent,
Sorry I can't get a Text message
Thanks,
Hugh
Old 06-09-2019, 11:58 AM   #15
duke36
Some of the repro radiator caps may not fit the new radiators. Use of a thermostat is subject to much discussion especially some purported lack of flow to the # 3 and 4 cylinders.
Old 06-09-2019, 12:24 PM   #16
diomed
diomed's Avatar
I bought a Berg's for my 1930 Tudor. Last summer I took it out on a 118 degree day to see what happened. Drove in street traffic, freeway, etc. Hottest it got was 210 in stop and go traffic. I was pretty happy with that. It also bolted right in, no modifications and all holes and brackets lined up.
kris
diomed is offline   Reply With Quote
Old 06-09-2019, 01:30 PM   #17
Railcarmover
I saved 3 out of 6 'bad' radiators by back flushing them with an industrial hot water/chemical pressure washer..Vintage precision thermostat does not impede flow to 3 and 4 cyl.
Railcarmover is offline   Reply With Quote
Old 06-09-2019, 07:03 PM   #18
old31
I installed a Bergs, it fit well and it cools cools cools.
old31 is offline   Reply With Quote
Old 06-09-2019, 07:10 PM   #19
37 Coupe
37 Coupe's Avatar
I don't think I have ever seen one bad or negative comment on Berg radiators since last fall when I started checking them out and bought one from Gary Bergbower.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 06-09-2019, 08:39 PM   #20
ericr
ericr's Avatar
no matter who you choose I would talk to them about your radiator shell, and whether there will be fit issues. the '29 radiator shell is an awkward fit originally and repros present problems.
ericr is offline   Reply With Quote
