01-05-2017, 05:40 PM | #1 |
31 Tudor Starter Quit Working
I am a newbie, I have had my car for 3 months. Today I adjusted the timing and then went to start it and left the cable that plugs into the distributor disconnected and cranked the motor and then the starter just quit working. I have not had an issue with the starter. I plugged the cable into the distributor, and the battery is fully charged, but nothing happens when I press the starter button. My car is a intact original with 22,000 miles on it. Any guidance is appreciated!
01-05-2017, 05:43 PM | #2 |
Re: 31 Tudor Starter Quit Working
put your tranny in high and rock the car back and forth. Sounds like a locked starter.
01-05-2017, 05:44 PM | #3 |
did that, nothing.
01-05-2017, 05:54 PM | #4 |
Did the engine turn over OK? If it did, the starter switch may need some attention.
01-05-2017, 05:56 PM | #5 |
it turned over but didn't start, then the starter quit
01-05-2017, 06:01 PM | #6 |
If so, then I would check the switch if all cables are tight and you have a good ground. |
01-05-2017, 06:05 PM | #7 |
Thats right the engine turns over in gear when I push it. I'll check the battery cables tomorrow but the lights are working fine. Don't know how to check the switch, maybe just order one?
01-05-2017, 06:09 PM | #8 | |
Of course it could always be a dead spot in the starter armature. Last edited by John Stone; 01-05-2017 at 06:10 PM. Reason: added |
01-05-2017, 06:13 PM | #9 |
Ok thanks!
01-05-2017, 08:26 PM | #10 |
Do the lights dim when you step on the starter?
01-05-2017, 09:45 PM | #11 |
BINGO
A quick easy check that will help diagnose the problem. If the lights don't dim, it would be a problem in the starter switch. If they dim, then it would be inside the starter, if the battery is in good condition. That is unless the switch contact is shorting to the cover. |
01-06-2017, 02:11 PM | #12 |
Thanks, the lights don't dim. I ordered a new switch. Hopefully thats it.
01-06-2017, 02:33 PM | #13 |
Try the hand crank starting. It may be a dead spot on the armature as suggested above. Or while you have the starter switch off, put the car in neutral, hand brake applied, touch the exposed copper disc on the top of the starter with the hot lead from the battery. Engine should turn over. Just some options.
01-06-2017, 02:38 PM | #14 | |
01-06-2017, 03:52 PM | #15 |
Take the switch apart. There is nothing to it.
01-06-2017, 11:43 PM | #16 |
[QUOTE=Rob Rose;I ordered a new switch. Hopefully thats it.[/QUOTE]
I agree with JACKSONIII I would take the switch apart and it may just need to be cleaned. Sometimes, a "new" part may not be nearly as good quality as the original. The original starter switched are very good and usually do not cause many problems. My opinion, Chris W. |
01-06-2017, 11:54 PM | #17 |
Location: Barren windswept mountain somewhere in bleak Northeastern Pennsylvania
Drove around often in Model A Ford cars for periods of time with a busted starter. Would park the thing on a slight grade, then let her roll and pop the clutch. It was usually broken bendix spring, bad switch or some standard situation. Great thing about an A Model Ford, it's usually pretty easy to get them started in a pinch.
I wouldn't be so paranoid if people weren't plotting against me all the time |
01-07-2017, 12:32 AM | #18 |
Put a voltmeter on the starter, using the + battery post as reference. If you have power to the starter switch, then check case of starter, should NOT be voltage there. Next pull off starter switch and touch battery cable directly to starter "nub". Use a voltmeter to verify power there. I would DEFINITELY fix the old starter switch rather than replace, if that proves to be the problem. Don't start throwing parts at the problem until you troubleshoot it down to the bad part.
01-09-2017, 12:25 PM | #19 |
Ok, I got the new switch and it does seem very simple-I haven't installed it yet, I am going to check and clean all connections including those in the old starter switch today, but I see that there is something that looks to me like a fuse marked 12V 30A. I unclipped it but I don't see if the back box opens to reveal a fuse inside. Could this be the problem? here is a pic of that.
01-09-2017, 12:45 PM | #20 |
That looks like a circuit breaker.
Bob |
