Old 06-01-2020, 03:18 PM   #1
32V8
Default 8ba in a 32 ford
hey guys, im trying to put a 8ba flathead in my 1932 ford with a 39 3 spd trans. it has the original k member and a model a lowered front crossmember .i am using typical round rubber motor mounts, but the od of them are to large and hit the sides of the frame when i try to put the motor where it should sit..any pics or info would be great thanks!
32V8 is offline   Reply With Quote
Old 06-01-2020, 03:27 PM   #2
Krylon32
Default Re: 8ba in a 32 ford
On all the 32 chassis I have built for myself and customers I put the weld on side mount brackets even with the top of the frame rails which leaves the top biscuit just a tiny bit on top of the rail.
Krylon32 is offline   Reply With Quote
Old 06-01-2020, 06:37 PM   #3
bobH
Originally Posted by krylon32 View Post
on all the 32 chassis i have built for myself and customers i put the weld on side mount brackets even with the top of the frame rails which leaves the top biscuit just a tiny bit on top of the rail.
x2...
bobH is offline   Reply With Quote
Old 06-01-2020, 07:25 PM   #4
Charlie ny
I put an 8BA in my '32 p'up and used '32 mounts....worked real nice.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 06-01-2020, 09:18 PM   #5
Krylon32
Charlie, That's how I'd do it if I had an original frame. Drake makes some nice original forged mounts. My reference above to how I mount my motors is in reproduction frames.
Old 06-01-2020, 11:33 PM   #6
RalphM
RalphM's Avatar
I think I welded on the mounts a tad below the frame, about 1/2” IIRC. I used a complete model A front crossmember, so I raised it just enough to clear the crossmember.
File Type: jpg 620D17A4-A0B8-4E9A-8146-AF8BBEEED82B.jpg (65.7 KB, 52 views)
RalphM is offline   Reply With Quote
Old 06-02-2020, 06:39 AM   #7
TomT/Williamsburg
TomT/Williamsburg's Avatar
Rather than remove and reweld the mounts, make up a shim of the appropriate thickness to put you above the frame and place them underneath your biscuits......
TomT/Williamsburg is offline   Reply With Quote
Old 06-02-2020, 03:47 PM   #8
hop up
hop up's Avatar
I like to use 1951 mercury water pumps and the risers. I have to ask how are your hoses lining up would be my biggest concern.
Wanted flathead speed equipment Thanks
hop up is offline   Reply With Quote
