Old 05-15-2020, 04:39 PM   #1
Clem Clement
Clem Clement's Avatar
Default Horn button removal 39 pickup
I've tried pushing in and turning.
I don't wish to break anything
Clem
Clem Clement is offline   Reply With Quote
Old 05-15-2020, 07:53 PM   #2
TJ
TJ's Avatar
Default Re: Horn button removal 39 pickup
On a stock 39 pickup the horn rod must be removed which gives access to the tabs on the underside of the rod. Those tabs must be straightened so that is releases the ring that holds the horn button. Re-bending those tabs to put it back together often breaks the tabs. Not a fun job. Why do you need to remove the button?
Old 05-15-2020, 09:37 PM   #3
ford38v8
ford38v8's Avatar
Clem, see my answer to that question on this thread:
https://www.fordbarn.com/forum/showthread.php?t=279494
Alan
ford38v8 is online now   Reply With Quote
Old 05-15-2020, 10:26 PM   #4
Tinker
Tinker's Avatar
I agree with Alan. Very hard to remove bolted to the dash.
Old 05-15-2020, 10:34 PM   #5
Clem Clement
thanks very much, in my 40MERC the button is rotated left and jumps right off. I'll check the light switch area. I'm not going to remove the rod.
Thread Tools
Display Modes
