Old 08-13-2020, 02:33 PM   #1
JCHarvey
Default Fuel Adjustment
When I turn the fuel adjustment knob (inside the car) counter clockwise or clockwise it just keeps turning without coming to a stop. I wanted to turn it all the way to left (counter clockwise) then open it about 1/4 to 3/4 to the position it runs best.
Is something stripped?
JCHarvey is offline   Reply With Quote
Old 08-13-2020, 02:38 PM   #2
ryanheacox
ryanheacox's Avatar
Default Re: Fuel Adjustment
Check that the knob hasn’t separated from the shaft. Repros have been known to do that.
Old 08-13-2020, 02:45 PM   #3
Tom Endy
Tom Endy's Avatar
I think you are turning it in the wrong direction. Turn it clockwise (to the right) to close it, then turn it to the left slightly to open to whatever you want.
Tom Endy
Old 08-13-2020, 03:54 PM   #4
Ruth
Tom Endy
What Tom says. If you keep turning it CCW it will eventually unscrew out of the carburetor.
Old 08-13-2020, 05:04 PM   #5
30 Closed Cab PU
The post says has is tried both ways, will not stop in either direction.
Old 08-13-2020, 06:31 PM   #6
Synchro909
Synchro909's Avatar
I ditto post 2
It is no burden to carry a little extra knowledge.
Old 08-13-2020, 07:13 PM   #7
The Master Cylinder
The Master Cylinder's Avatar
It never would in the CCW direction.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 08-14-2020, 12:02 AM   #8
Bill G
Bill G's Avatar
Maybe lift the hood and separate the GAV shaft from the needle shaft and look and see? You're going to have to take a look to actually know.
-Bill G
Member of Walla Walla Sweet A's Model A Club
Old 08-14-2020, 04:01 AM   #9
johnbuckley
johnbuckley's Avatar
and whilst you're at it check the threwads of the needle are actually engaging into the threads of the GAV housing!
Old 08-14-2020, 05:14 AM   #10
JD 1931
JD 1931's Avatar
Check choke driver on carb, , it may be broke....
JD 1931 is offline   Reply With Quote
Old 08-14-2020, 05:19 AM   #11
DBSHELTON
I just had this problem. The threads were all still good but I used some Loctite on the knob. Problem fixed.
DBSHELTON is offline   Reply With Quote
Old 08-14-2020, 12:40 PM   #12
Smooth_One
Smooth_One's Avatar
Side note... I put a dab of dielectric grease on my choke rod threads and it works MUCH better now. Doesn’t help your problem but I thought I’d add the info.
Isaiah B.
1928 all metal Tudor
Smooth_One is offline   Reply With Quote
Old 08-14-2020, 02:42 PM   #13
JCHarvey
Thanks all for the correct direction to turn the fuel adjustment knob. It makes complete sense to turn CW to close and CCW to open.
Mine is fairly stiff to turn so may try the dielectric grease.
I turned the knob CW until closed then opened about 1/2 to 3/4 turn and am still having problems getting it to run as good as it did before. It just seems like it starved for fuel. There is a slight pause, almost like a miss. I've been experimenting with turning the fuel adjust know 1/4 to 1/2 more CCW and that doesn't seem to help. Prior to this it was running great without any indication that it was starved for fuel.
Old 08-14-2020, 02:53 PM   #14
DBSHELTON
Possibly trash in the carb?
Old 08-14-2020, 06:07 PM   #15
Licensed to kill
Licensed to kill's Avatar
I would clean the carb with carb cleaner, generously sprayed in every orifice, then clean the plugs, set your GAV to 1/2 turn out and go for a drive at highway speed for 10-20 miles then pull the plugs and check the colour. The you will know if you are lean, rich or good on the fuel side of things. MOST people report that they run the GAV at 1/4 turn out but my car requires 1 full turn even with an air filter to achieve a nice light tan colour to the plugs. At 1/2 turn the plugs run white and it stumbles and lightly backfires occasionally.
Licensed to kill is offline   Reply With Quote
Old 08-20-2020, 01:50 PM   #16
JCHarvey
Here's what I found was the problem.
As noted above the car was running but not correctly. Found all four plugs were fouled. Cleaned the plugs and reinstalled and it drove better but still not right. Fiddled more with GAV knob and figured out I had it turned all the way out. Apparently when I was trying to adjust it before the threads got stuck and there was a hard place which I thought was full CW but once I actually turned it all the way CW then backed off 1/4 turn, it runs great. Simple problem that helped me learn a little more about the car.
Old 08-20-2020, 07:48 PM   #17
Big hammer
The Ford Barn thanks you for your posting as how you solved your problem ! Now go for a long drive :-)
get a bigger hammer tap done
Old 08-20-2020, 11:53 PM   #18
1930-Pickup
Originally Posted by Smooth_One View Post
Side note... I put a dab of dielectric grease on my choke rod threads and it works MUCH better now...
Thanks all...
I turned the...
This is how really weird myths get started
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 08-21-2020, 05:38 AM   #19
Patrick L.
Patrick L.'s Avatar
That grease will let all those electrons flow so much easier !
Old 08-21-2020, 08:23 AM   #20
DannL
DannL's Avatar
You can go to google and search for "ford model a instruction" and a link to th original manual should be made available from Palm Beach Ford Model A's. Page 22 covers the GAV. I have used it often.
Not a Purist.
DannL is online now   Reply With Quote
