Old 08-10-2020, 06:34 AM   #1
toms32
Default how tell the difference between 39-41 and 42-48
I have forgotten how to tell the difference in juice brakes between i believe it was 39-41 and 42-48. I think if was difference in adjustment in linings, Can some one out there tell me how to tell the difference thanks Tom
toms32 is offline   Reply With Quote
Old 08-10-2020, 06:38 AM   #2
deuce lover
deuce lover's Avatar
Default Re: how tell the difference between 39-41 and 42-48
39-41 have bottom eccentric adjustments.There are 2 large lock nuts at the bottom of backing plate that face the banjo .
Old 08-10-2020, 06:41 AM   #3
Tim Ayers
42-48 also have a dimple in the stamping inside the lower recess.
Old 08-10-2020, 07:44 AM   #4
19Fordy
19Fordy's Avatar
Here's 1940. The 2 white dots are where the "dimples" are on the adjusters.
Old 08-10-2020, 09:12 AM   #5
V8COOPMAN
V8COOPMAN's Avatar
Like others have pointed-out, the '39-'41 has adjustable (with lock nuts) shoe pivots as seen just below. The 'later ones have the fixed pivots, as seen here in the picture on right. DD
T5 W/TORQUE TUBE
In that final nano-second while the metal bar speeds toward his furry little head, the oblivious mouse FINALLY realizes WHY the cheese was free!
Old 08-10-2020, 12:20 PM   #6
toms32
Many thanks guys for the info Tom
Old 08-10-2020, 01:16 PM   #7
Mart
Mart's Avatar
If you're looking at shoes, the earlier type have round holes. The later type have a hole with two flats.
The shoes sit on pivot washers the early type are round on the outside with a sort of round hole in the middle except it has one square corner. (sounds daft). The later pivot washers have a round hole in the middle and are round on the outside except for two flats.
The backplates also use different types of shoe retaining springs. The later backplates also have three pads each side for the shoe to sit on.
Mart.
