08-06-2020, 08:28 AM | #1 |
It’s a thing of beauty! But now some questions…
After a month in the clutches of the USPS, my reground Isky 1007B camshaft FINALLY arrived from D&L Automachine (Thanks, Pete1!). Ain’t it pretty? Seriously, it’s almost too nice to use…
Anyway, as I start sourcing parts for the engine in my 1951 Ford, I have a few questions. 1. What valve springs should I run with this cam? I’d like the lowest seat pressure I can get away with. Would stock springs work? 2. What brand of valves and/or what vendor do you recommend for purchasing valves? 3. I’ve got a nice set of EAB heads. Can I run them with a 4-inch Mercury crank? If not, I also have a smattering of 8BAs. I assume shoot for around 0.050" piston-to-head and valve-to-head clearance, right? 4. For simplicity and drivability, I plan on running a single carburetor. Do the four-bolt Mercury intake manifolds flow more than the three-bolt Ford units or are they pretty much the same? Not sure if finding a Merc unit would be an improvement. |
08-06-2020, 08:41 AM | #2 |
Re: It’s a thing of beauty! But now some questions…
Admiral, Charlie NY did a 1 1/16 throttle bore 94 style carb for my 8BA with max 1 in it.
You could feel the difference, over the stcok 1" diameter 94. Just say'n. Charlie is easy to talk with..... Good luck & have fun! mike |
08-06-2020, 08:50 AM | #3 |
Thanks for the feedback, mfirth! Actually, I've got a 1 1/16"-bore Holley rebuilt and ready to run. Glad to hear they work well with this sort of combination. I'm shooting for good drivability, lots of low- and mid-range torque, with a little more oopmh than stock. Also, you're totally right about Charlie. He's SUPER nice, helped me order some parts to rebuild that carb, actually.
08-06-2020, 08:56 AM | #4 |
I’d talk to Pete on your valve questions...Im going to use a Merc intake on my next engine. Like the idea of the bigger bore 94..... Mark
08-06-2020, 10:29 AM | #5 | |
I will admit that I am a great booster of a 2G on a bored out merc manifold. The one problem I am having is getting the throttle to open all the way. Even with the throttle only opening 3/4 way, the increase in performance is impressive. |
08-06-2020, 11:16 AM | #6 |
I'm also using a 2G on a bored Mercury manifold and a Charlie NY chevy distributor. Overall, it is a. good, reliable system. I just wish I had used one of Pete's 1007B cams. |
08-06-2020, 11:23 AM | #7 |
I liked the idea.... but obviously I would need to do more research. The way I read his post the big bore 94 was a Merc carb and was four bolt. When I’m ready to do the swap, maybe I can pick your brain on 2G info...... Mark
08-06-2020, 12:13 PM | #8 |
If you're referring to me, please do, as I have done several. I have a jig that you can use to bore the manifold and had a bunch of 1/8" aluminum plates made to seal off the bottom of the 2G, which has some odd heat passages cast into it.
08-06-2020, 04:49 PM | #9 |
Yes, thanks. I had never heard of a “big bore-94” so I assumed it was a Merc carb. We all know what happens when we do that ...... Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver Last edited by flatford8; 08-06-2020 at 06:11 PM. |
08-07-2020, 05:21 PM | #10 | |
I think I'd like to run valve rotators for perhaps slightly improved longevity. Any idea if these work with the undercut, 1.5-inch Chevy valves? Other than the four-bolt carburetor mount, is the Mercury manifold any different than the Ford design? Do they flow more? |
08-07-2020, 05:40 PM | #11 |
In stock form I remember that the rotator valve keepers utilized a shorter spring than the non-rotators, but i don't remember how much shorter. I might be enough that you don't need shims. Or maybe too much if you don't use short springs. Maybe someone will chime in with the difference in length.
I can't help you with the flow differences. |
08-07-2020, 05:45 PM | #12 | |
Take a look down an intake manifold and see what you think. |
