Old 07-15-2020, 05:11 AM   #1
aussie merc
aussie merc's Avatar
Question 39 brake drums
just a question for the future does anyone make replacement wide 5 drums
aussie merc is offline   Reply With Quote
Old 07-15-2020, 07:27 AM   #2
Juergen
Default Re: 39 brake drums
I have never seen them advertised by any of the big suppliers.
Juergen is offline   Reply With Quote
Old 07-15-2020, 09:41 AM   #3
51504bat
51504bat's Avatar
There is a company I believe in the mid west that rehab's brake drums. Not cheap IIRC. I have the contact info somewhere (I think). Maybe someone will chime in with the info.
Found it: https://www.jgrelining.com/
Old 07-15-2020, 09:59 AM   #4
tubman
tubman's Avatar
If you get a price from them, could you let us know? I am afraid it will be very high (that company specializes in redoing Pontiac 8-lugs, and you know how much money those guys have).
Old 07-15-2020, 01:21 PM   #5
1931 flamingo
1931 flamingo's Avatar
I believe there's a couple on the HAMB for sale, also here on the BARN.
Paul in CT
Old 07-15-2020, 03:27 PM   #6
Clem Clement
Clem Clement's Avatar
In the US, we used them up running on dirt tracks. They don't flex;
I found some at Hershey but tough to find them with any meat left
Old 07-16-2020, 03:07 AM   #7
Ray Balukas
Ray Balukas's Avatar
J&G Relining!! used them for my drums, Top Notch ! They will also arch your shoes. They are on the web
Ray Balukas is offline   Reply With Quote
Old 07-16-2020, 03:47 AM   #8
tub1
tub1's Avatar
hello aussie merc if you need some drums ive got a perfect set
tub1 is offline   Reply With Quote
Old 07-16-2020, 08:17 AM   #9
Dave/Green Bay
MT Car Products
From their website
"These drums will work with our backing plates or with original 1939 - 1948 ford hydraulic backing plates. They come in the stock 5 on 5-1/2" pattern.
Sold each $135.00"
They must be used with hubs that mount inside the drums 39-40. When I talked to him he said 46-48 with hub on outside will not work.
Has anyone had experience using them?
Dave/Green Bay
www.mtcarproducts.com/
Dave/Green Bay is offline   Reply With Quote
Old 07-16-2020, 09:01 AM   #10
CA Victoria
CA Victoria's Avatar
I couldn’t find my quote from J&G but if memory serves me they were just north of $300for Drum and shoes (1935 Ford). From their website they work on a wide scope of drums and the quality looks superb. The drum is restored to original.
Since original drums are still popping up I elected not to go down this road yet.
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 07-16-2020, 09:29 AM   #11
51504bat
51504bat's Avatar
Hard to find wide five's that aren't worn beyond allowable tolerances.
Old 07-16-2020, 09:52 AM   #12
Dave/Green Bay
Just call J&G and it is around 300 dollars per drum to repair to std.
Old 07-16-2020, 10:28 AM   #13
cas3
what do they do, sleeve it, or spray weld it back to size?
Old 07-16-2020, 04:36 PM   #14
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by Dave/Green Bay View Post
MT Car Products
From their website
Sold each $135.00"
Dave/Green Bay
Be careful how you read this info. The "drums 39-40" quoted above is incorrect, as '39 drums are WIDE FIVE. That should read "drums '40-'41". What they are actually TRYING to say is that their '40 -'41 replacement DRUMS will function properly and fit properly when using '39-'48 hydraulic backing plates. NOTE...that wheel studs will have to have the swages cut and each stud removed to separate hub and old drum. The swaged studs must be cut and removed PROPERLY so as not to bend hub's flange. The MT parts are of the utmost quality. Don't settle for the Speedway 'look-alikes'! They ain't the same as MT drums. DD
T5 W/TORQUE TUBE
In that final nano-second while the metal bar speeds toward his furry little head, the oblivious mouse FINALLY realizes WHY the cheese was free!
Old 07-16-2020, 04:39 PM   #15
V8COOPMAN
V8COOPMAN's Avatar
cas…..I'm 99.9% sure that I've read that they re-sleeve the drums. Their web site is interesting. Someone linked it above. DD
T5 W/TORQUE TUBE
Old 07-16-2020, 04:58 PM   #16
cas3
thanks coopman
Old 07-16-2020, 05:15 PM   #17
5851a
I know 300 a wheel seems like a lot but a disk conversion can be expensive. The new Mustangs have some mega dollar super brake option. They can keep the pretty painted calipers, wide 5's are total class.
5851a is offline   Reply With Quote
Old 07-16-2020, 06:58 PM   #18
bobH
Interesting.... sleeve back to size? Using WHAT for material?
bobH is offline   Reply With Quote
Old 07-16-2020, 07:59 PM   #19
V8COOPMAN
V8COOPMAN's Avatar
Guys...…….:
Our Services include:
  • Cosmetic Restoration to Brake Drums
  • Repairing Broken & Damaged Aluminum Fins
  • Installing New Cast Iron Liners
  • Reline and Arc Brake Shoes
  • Balancing Pontiac 8-Lug Wheels
  • Relining Brake Bands on Early Model Vehicles
  • Left & Right Handed Pontiac 8-Lugs
We are the only company that uses a THREE-STEP PROCESS to install new cast iron liners into the drum. Why? We value safety!
CHECK-OUT THEIR WEB SITE! They use cast iron liners! They show pictures of the process, PLUS the repair of broken parts of the same aluminum Pontiac wheel. They do some high-dollar, irreplaceable stuff. Make sure you click on "PHOTOS". Click on the link below! DD
T5 W/TORQUE TUBE
Old 07-18-2020, 09:49 PM   #20
aussie merc
yeh thanks got a price to rebuild drums with metal spray localy not cheap but still reasonable when you add up the on costs of changing to 40s or going all out with full discs As i said a question for the future thanks for all the input
