05-24-2020, 08:28 AM | #1 |
Almost a fire in the 36
Out for a ride yesterday when I smelled burning wires. Pulled over , lifted one side of the hood and saw that the wire to the voltage cutout which sits on top on the generator had burnt back the wiring insulation about 6 inches exposing a red hot copper wire. I used a kill switch to shut all power down.
When I finally got the car home, I pulled off the cutout switch off the generator and opened it up to see what happened. The points had been melted together.... COULD THIS HAVE BEEN PREVENTED ? Or was this just a freak thing ? Does anyone know what the point gap should be on a 36 cutout ? |
05-24-2020, 08:56 AM | #2 |
Re: Almost a fire in the 36
I hate fire! To eliminate the cut out check with funprojects.com. They work for A and Ts. Should be something for yours too. Nice folks.
Enjoy yer day. Tom Hate can't fix what it started. |
05-24-2020, 09:18 AM | #3 |
Yes - checkout the updated voltage regulator that is made to look like a regular cut-out. I ran one of these for quite some time - worked flawlessly:
http://funprojects.com/products/10505v.aspx |
05-24-2020, 10:32 AM | #4 |
Wll order one Monday....thanks
05-24-2020, 11:18 AM | #5 |
As a suggestion pry the contacts apart and run a point file across them. the contact gap is not significant. put it back together and try it to make sure you have found the problem area, before installing the new Fun Projects regulator. Closed contacts while the car is running is no problem. Closed contacts with the car turned off is a problem. You may have another problem that caused the contacts to fuse together such as a short in the wiring.
05-24-2020, 11:43 AM | #6 |
05-24-2020, 12:44 PM | #7 |
Check you generator. It maybe fried also. The Fun Product replacement had been on back order for some time. I hope there back in stock as I need a couple.
05-24-2020, 02:03 PM | #8 |
get the one with a dioed
05-24-2020, 05:01 PM | #9 |
Look like still on backorder per their website
05-24-2020, 05:27 PM | #10 |
I would go with Terry's suggestion, best to trouble shoot the problem first with a cutout you can sacrifice.
05-26-2020, 09:42 AM | #11 |
05-26-2020, 12:06 PM | #12 |
I called them, they are now called BIRD HAVEN, they have no idea when they will have them available.. The tel #is 515-674-3949.
I believe the problem with the cutout was that the power wire shorted against the can. The insulators were really flattened out. I was able to free up the points using a propane torch and then dressed the points with sand paper. I replaced the insulators and installed the cutout back on the generator and started the car and the amp meter shows the gen is charging. I will keep a close eye on it.... |
05-26-2020, 08:24 PM | #13 |
Sandpaper is a big no no for any contact points. The grit comes looses from the paper and embeds into the contact metal.
05-27-2020, 10:17 PM | #14 |
Terry...I misspoke. I used 1500 3m paper. Not sure what type other than no actual sand in it. Thanks ..
