Old 05-01-2020, 05:08 PM   #1
Clem Clement
Clem Clement's Avatar
Default Choke/Throttle rods
Thanks in advance for all the help you folks have been.
I'm messing with the choke/throttle linkages. Some time back I redid the carb, 91-99. The c/t rods don't function much, It is like I have something wrong in my assembly. One rod is too long and the other too short. What gives, please?
Clem
Old 05-01-2020, 06:16 PM   #2
30-9
Default Re: Choke/Throttle rods
Reverse them?
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 05-01-2020, 06:26 PM   #3
drolston
drolston's Avatar
What year?
Rods or cables?
Stock intake manifold?
Old 05-01-2020, 06:40 PM   #4
Kube
Kube's Avatar
Clem
Clem, you have them reversed.
Old 05-01-2020, 08:59 PM   #5
Clem Clement
39 Ford standard intake. I did not remove them from the dash holes
Old 05-01-2020, 11:30 PM   #6
Clem Clement
You guys got me to thinking. We let the truck sit for sometime when I first got it. I know the rods fit and worked at that time. I was still working. A fellow clubber came by and helped figure out what we had and to help get it going. I also got some spares with the truck. Somewhere in the process We found that I had a carb that fit his 40 Ford. He needed it so of course I gave it to him. Could that carb have been built differently? Also we noted that the rubber pivot on the C/T rods was welded in place. I have original rods now thanks to Fordbarn. I'm thinking to try and remove the rods are replace them with the original ones.
The carb on my truck is a 91-99
Thanks, Clem
Old 05-02-2020, 07:18 AM   #7
Kube
Kube's Avatar
Okay, I'll bite... WHAT YEAR vehicle? WHAT MODEL?
Old 05-02-2020, 08:44 AM   #8
Clem Clement
39 Ford Pickup
Old 05-02-2020, 09:38 AM   #9
Kube
Kube's Avatar
39 Ford Pickup
Clem, If the rods fit at some point and they were never removed and possibly reinstalled improperly,well, that leaves only "option B".
What has changed since they worked?
A properly assembled 91-99 carburetor is correct for your truck.
Also, what do you mean by a "39 standard intake"?
Truck rods are very different than the passenger car rods.
Old 05-02-2020, 12:15 PM   #10
Clem Clement
Sorry for not being clear. I'm, still recovering and I so good, don't type
factory intake. 91-99 carb. I'll replace the C/T rods
Old 05-15-2020, 04:36 PM   #11
Clem Clement
I gave up. When we can visit I'll get help.
Old 05-15-2020, 07:48 PM   #12
JSeery
JSeery's Avatar
Hopefully it won't be too much longer, but us older guys have to be careful!
Old 05-15-2020, 09:34 PM   #13
51504bat
51504bat's Avatar
Maybe a photo or 2 would help shed some light on it?
Old 08-22-2020, 10:05 PM   #14
Clem Clement
Worked in the rods again today. Bought a pair of rods from a Barner. The choke rod has a loop-de-loop to shorten it The Throttle is long as well. I have kept the originals in and made some improvements. the carb us a 91-99 the carb is raised 3/4" by the phenolic block. Wrong carb?
Old 08-22-2020, 10:26 PM   #15
Will D
Will D's Avatar
The phenolic spacer is probably the issue. When I added one on my '38 the rods protrude 3/8" - 1/2" into the cab past their previous position on the dash. I just put the same thickness rubber washer in behind the knobs so it looks clean and if I remove the phenolic spacer the rods will fit as they did before.
Will D is offline   Reply With Quote
Old 08-23-2020, 10:17 AM   #16
Clem Clement
Thanks. Great idea. I can split vacuum hoses to cover the rods and be a stop for the push - in action.
Did the phenolic block help with vapor lock?
Old 08-23-2020, 11:00 AM   #17
Will D
Will D's Avatar
I'm going to say yes but I think I had other issues as well which have since been resolved. Either way I left it on and have not vapor locked since the install.
Old 08-27-2020, 02:07 AM   #18
Clem Clement
Thanks Barners. I am still recovering from heart procedures and am very slow. I took time off from car work during the hot summer. I am slowly starting again. Thanks for understanding.
I split 2 short pieces of vacuum hose and put them over the choke/throttle rods. Looks good in the cockpit.
Old 08-27-2020, 03:31 PM   #19
JSeery
JSeery's Avatar
Heart surgery is always fun, I've had a quad-bypass.
Old 08-27-2020, 03:39 PM   #20
Ken/Alabama
Ken/Alabama's Avatar
Oh yes, I had a six way last year and it takes a while to get back at it and itís still not a 100% , probably never will be
