Old 04-16-2020, 01:26 PM   #1
Farley's34
Default 1932 Horn Rod
Can a horn rod be removed/installed in a stock 32 5W without unbolting the steering box ? I'm not sure if there is enough room...
Farley's34 is offline   Reply With Quote
Old 04-16-2020, 01:42 PM   #2
DavidG
DavidG's Avatar
Default Re: 1932 Horn Rod
Yes, it can be removed by pulling out the C-shaped clip that retains it at the bottom. A wood or plastic yard stick wedged over the horn button and under the sides of the steering wheel works wonders in keeping the spring at the bottom compressed so that you can access the clip. Unless your car is a roadster, phaeton, cabriolet or convertible sedan where you can lower the top, you will need to loosen the three bolts attaching the sector gear housing to the chassis frame rail and unfasten the steering column from the dash to lower the whole column. Otherwise, you'll likely irrevocably bend the horn rod removing it.
Old 04-16-2020, 02:40 PM   #3
Farley's34
Thank You, David.
Old 04-16-2020, 02:52 PM   #4
Charlie Stephens
If you have a closed car with a roof that needs to be replaced this might be the time to do it.
Charlie Stephens
Old 04-16-2020, 07:51 PM   #5
Farley's34
I have a 5W that is ready to go back onto it's chassis that doesn't have it's steering wheel or horn rod installed yet.
