07-05-2019, 07:59 AM | #1 |
clutch - embarrassing question.
So, I took this non-running flathead/transmission apart over a decade ago, and recently had her machined and outfitted with new parts. Now come the day when I mate the motor to the trans, fresh VanPelt clutch in hand. ...and I cant remember which way the clutch disk goes on. "spring side" towards the transmission or towards the motor. And by "spring side" I mean the side with the protruding spring plate.
Thanks! Carl PS - please don't tell my gear-head friends at the bar that I asked. |
07-05-2019, 08:07 AM | #2 |
Re: clutch - embarrassing question.
springs face the trans
07-05-2019, 08:13 AM | #3 |
Thank you!!!
07-05-2019, 08:31 AM | #4 |
Some clutch plates are marked "Flywheel side" you might look for that.
Mart. |
07-05-2019, 08:32 AM | #5 |
Don't be embarrassed! I had to refer to the clutch section of the "Green Bible" to get mine together right. Not something I do everyday!!
07-05-2019, 08:38 AM | #6 |
07-05-2019, 09:00 AM | #7 |
Thanks for asking because I would have been searching for the same answer soon. But, on a similar note what do you all use for alignment to get the clutch plate centered on the flywheel?
Sent from my LM-G710VM using Tapatalk |
07-05-2019, 09:30 AM | #8 | |
Get yourself that little plastic alignment tool....it's a piece of cake!! |
07-05-2019, 10:07 AM | #9 |
I bought a clutch kit from Mac VanPelt and that tool is included - very helpful.
Thanks again all, I'm old enough to know it's better to ask early and save myself a world of headache. |
07-05-2019, 10:44 AM | #10 |
I thought everybody had an old transmission front shaft in their junk box for installing clutches!
07-05-2019, 10:49 AM | #11 |
!!!FOLLOW UP QUESTION!!!!
So here is my situation I have a big buddy over here to help me install the transmission with promises of beer and loose women (though I can only provide the beer) but I'm missing my throwout bearing return spring. Can I install that later through the inspection plate on top? ...and do I need to "proper" spring or will a hardware substitute work? Thanks again! |
07-05-2019, 10:49 AM | #12 |
07-05-2019, 11:01 AM | #13 | |
07-05-2019, 04:43 PM | #14 |
I wish I did. This has been an ongoing hobby project for many years. Not something I do often enough to accumulate that assortment tools like a stub shaft. I'm guessing not just any shaft fits a 48 F3...
07-06-2019, 07:58 AM | #15 |
Put the correct first. Can't imagine being able to do it later. When I replaced the clutch in my 52 F-1 I had my new clutch and PP ready to go and after a closer look found that the TO Hub was worn. Had Mac van Pelt send me a new hub and spring. Then put it all together. Easier than doing it all over again in a month... Chap
07-06-2019, 08:06 AM | #16 |
Good advice all. Thanks!
