Old 10-12-2018, 01:19 PM   #1
DC 69
Question Rear Spring Perch Repair
Greetings from California.
I'm wanting to repair both rear spring perches on my '29 CCPU. Asking for advise on best/easiest way to remove from pickup in order to deliver to the shop. I have Les Andrew's Handbook, vol. 1.
After removing Tires & Backing Plates, should I:
1. Disconnect torque tube at Banjo; deliver entire axle
or
2. Remove each axle housing; deliver just housings
or
3. Other
Thanks in advance for your advice.
DC 69 is offline   Reply With Quote
Old 10-12-2018, 02:37 PM   #2
wmws
Default Re: Rear Spring Perch Repair
#1 unless you want to redo your rear.
wmws is offline   Reply With Quote
Old 10-12-2018, 02:42 PM   #3
john in illinois
john in illinois's Avatar
If you are planning to rebuild rear end,then you could take it apart. If not then take off backing plates and take entire axle. Are the perch holes too worn to repair by new bushings?
John. Typed too slow!
john in illinois is offline   Reply With Quote
Old 10-12-2018, 06:44 PM   #4
wmws
John has a good point. Are your perches really shot or can you just re bush them? That would be a lot easier.
Old 10-12-2018, 10:04 PM   #5
jw hash
jw hash's Avatar
leave the torque tube bolted the rear end. if you take the rear whole to someone who knows what they are doing. it is not a big deal to repair them.
jw hash is offline   Reply With Quote
Old 10-13-2018, 03:18 PM   #6
duke36
Concur to do #1,but get a rear spring spreader to be safe. The vendors sell one ( not the traveling type) at reasonable cost and leave the spring attached to the cross member.
duke36 is offline   Reply With Quote
Old 10-15-2018, 01:58 AM   #7
Big hammer
#3 leave the wheels on, you can then roll the axle around! A lot easier than picking up a complete reared :-)
get a bigger hammer tap done
Old 10-15-2018, 07:44 AM   #8
rocket1
If the bushings are just worn and perches good get a spring spreader and disconnect shackles,bushings can be pressed out with a bolt washers and a piece of pipe.Use extreme caution when using spreader,spring can be lethal!
rocket1 is offline   Reply With Quote
