07-25-2015, 11:06 AM | #1 |
Timing
I've reviewed all the manual timing procedures out there. Checked mine by manually cranking over the engine and observing the #1 plug spark at around TDC when I was thru adjusting. Up until now I've mostly had a mechanical advance distributor and electronic ignition on my 2 As like a Model B or a Mallory. However I want to check with a timing light. I have marked the pulley with a scratch and have a timing indicator. What should the final timing read when checked with a timing light and the advance all the way up for starting?
07-25-2015, 11:09 AM | #2 |
Re: Timing
From 0º to almost 40º
07-25-2015, 11:13 AM | #3 |
Re: Timing
07-25-2015, 11:48 AM | #4 |
Re: Timing
0° to 40° BTC is quit a range. I would be interested to know what the timing is when the advance lever is all the way up for starting also. Or actually what the timing would be "1-2 notches down on the advance lever" per Andrew's "Red Book".
I would like to check my static timing with a buzz box and a ° scale on the pulley. Last edited by Y-Blockhead; 07-25-2015 at 11:57 AM. |
07-25-2015, 12:31 PM | #5 |
Re: Timing
Model A
Timing supposed/normally set at TDC, lever up. Timing thru lever arc at distributor should be about 20º That means 40º at crank Model B is different. A model A with model B distributor, model A or model B timing cover which are different, all bets are off. The way to check for advance vs lever position would be to use a timing with an advance mode, or, a plain jane timing light with an advance tape. Set the lever and read the advance. |
07-25-2015, 12:34 PM | #6 |
Re: Timing
V4f |
07-25-2015, 12:42 PM | #7 |
Re: Timing
Thanks V4F, that's just what I needed.
07-25-2015, 12:55 PM | #8 |
Re: Timing
With the lever all the way up (Retard), the timing, per the Ford service info should be 0 degrees.
Les Andrews method has the 0 degree indication 2-3 clicks down. Marc |
07-25-2015, 12:56 PM | #9 |
Re: Timing
5 after tdc?
07-25-2015, 01:02 PM | #10 |
Re: Timing
07-25-2015, 01:29 PM | #11 | |
Re: Timing
Bill W.
07-25-2015, 01:36 PM | #12 |
Re: Timing
I'd like to know why any of my responses are so hard to understand, they make perfect sense to me. [ smiley face]
07-25-2015, 01:46 PM | #13 |
Re: Timing
If nobody has messed with the slot in the distributor cap you should see 0 deg. or TDC with the lever all of the way up and 40-42 deg with it all of the way down. I don't think the timing light is worth messing with though, set it lever up with the cam pin and listen to the motor as you drive it. It'll tell you how much adv. its happy with
07-25-2015, 01:51 PM | #14 | |
Re: Timing
We all do pretty good, considering that we CAN'T talk, use our hands, read faces or draw pics--GOOD thing we don't use video cams, Buster T. LAFFS, when I scratch my butt or pick my nose Bill W.
07-25-2015, 02:08 PM | #15 | |
Re: Timing
