Old 06-15-2018, 11:33 AM   #21
rotorwrench
rotorwrench's Avatar
Default Re: How to fix ribs??
I wouldn't cut them out unless they was no other way to repair them. I'd first try to make a tool to buck the back side so it can be smoother out in place. Cutting is a last resort. Those 1937 grills are pretty delicate. If you remove one, you will need equipment and skill to weld thin small parts without melting the stuff. If there is plating on it, it will have to be completely removed. If it is stainless, you will need to fabricate tooling to deal with each problem that is different such as dent or twist. If you fabricate a tools with the proper width, radius, & curvature to fit in the backside of the bars, you can work them but you will have to gentle on those small grill bars. If the bars are spot welded in place then they can be removed and spot welded back but it takes experience with welding stainless or what ever material it is. Resistance welding equipment isn't cheap.
Old 06-15-2018, 02:47 PM   #22
slantback37
slantback37's Avatar
Okay Thanks. I will see what I need. If I have to make ribs. I will cut them from one of those fake grills. They have to be good for something..
slantback37 is offline   Reply With Quote
Old 06-15-2018, 09:48 PM   #23
Tinker
Tinker's Avatar
Originally Posted by markdtn View Post
Never boil ribs!
Ha ha Ya I agree. It's a quick rib fl method. You'd be surprised how good it is and quick/easy to do, probably most common restaurants you get "ribs" at do it. I prefer to marinate 24hrs and then smoke them with applewood. Unless I want to make ribs in 2hrs. Try it before saying, never say never.
Tinker is online now   Reply With Quote
Old 06-16-2018, 07:56 AM   #24
mfirth
Pun intended here...just put the ribs on the grill......
All kidding aside, you have a sweet ride ....love the slantback !
mfirth is offline   Reply With Quote
Old 06-16-2018, 09:37 AM   #25
bill3337
bill3337's Avatar
I have several grille sections, one really nice top section (about a foot or so) with nice straight bars that would be good for repairs/replacements. If you're interested I can shoot you a couple photos.
bill3337 is offline   Reply With Quote
Old 06-16-2018, 02:26 PM   #26
slantback37
Here is the Grille, and one of the problems I have.
