Old 10-14-2020, 12:21 PM   #1
PKW181
Default 57 Fairlane parts
Hi all,
Anyone know of a source for heavy duty anti sway bars for my 57 Fairlane,
also for a rebuild kit or a rebuilt steering box (non power)?
Many Thanks in advance for any help.
Also asked over on 57 Fords forever.
PKW181 is offline   Reply With Quote
Old 10-14-2020, 01:22 PM   #2
55blacktie
Default Re: 57 Fairlane parts
I sent my 55 Tbird steering box to Redhead Steering Gears in Washington to be rebuilt. Any of the Ford parts suppliers will have rebuild kits, or will rebuild yours. I would use Redhead again.
55blacktie is offline   Reply With Quote
Old 10-14-2020, 02:38 PM   #3
Dobie Gillis
Dobie Gillis's Avatar
For the steering box there's also Lares Corp.
https://www.larescorp.com/
I googled for the sway bar but the only thing that comes up is for the T-bird. Maybe the same as a Fairlane but unlikely. Polyurethane bushings on the stock sway bar may get you where you want to be. I've got 'em on my Merc and they work fine. Check Energy Suspension; you may need the measurements of your old bushings to match 'em up. Be sure to get the special grease or they'll drive you batsh!t with the squeaking.
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 10-14-2020, 02:45 PM   #4
55blacktie
If you decide to rebuild the steering box yourself, fill it with 00 grease. That's what Redhead used because they are prone to leakage. Mine was bone dry when I removed it. That was also a problem with early Corvette steering boxes. GM's warranty fix was 00 grease.
Old 10-14-2020, 04:36 PM   #5
KULTULZ
KULTULZ's Avatar
Post Re: 57 Fairlane parts
Here you go -
https://www.addco.net/product/ford-f...-1957-59-rear/
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 10-14-2020, 05:35 PM   #6
dmsfrr
dmsfrr's Avatar
and here's their front sway bar...
https://www.addco.net/product/ford-f...1957-59-front/
Old 10-14-2020, 09:00 PM   #7
miker98038
miker98038's Avatar
FWIW, I bought a rear bar from Addco for my 55 bird in 1967 or 68. I'm pretty sure the ones on my bird now are Addco (1999 or so). So they've been around a long time.
miker98038 is offline   Reply With Quote
Old 10-16-2020, 09:55 AM   #8
PKW181
Thank you for all the help.
Concours had the parts I was looking for.
