Old 03-01-2020, 02:41 PM   #1
barnnone51
Default Front Fenders
Will the front fenders off a 1930 31 Tudor work on a 1930 Coupe? It looks like they will but need to be sure because the splash aprons are the same or look
like they would work.
barnnone51 is offline   Reply With Quote
Old 03-01-2020, 03:00 PM   #2
keyswitch1
Default Re: Front Fenders
I could be wrong but I do not think so.
keyswitch1 is offline   Reply With Quote
Old 03-01-2020, 03:11 PM   #3
juke joint johnny
juke joint johnny's Avatar
Some of the early 30 fenders had a nose piece of the splash apron welded to the fender ,
The later 30-31's had a long splash apron .
If your coupe has the long splash aprons the fenders are the same as the 31's and will fit your car
juke joint johnny is offline   Reply With Quote
Old 03-01-2020, 05:24 PM   #4
larrys40
Yes , all passenger cars are the same. As was noted the 30’s had a front nisecsenction and a shorter apron to match and the ‘31 style apron when introduced eliminated the apron section being spot welded to the fender.
Fit wise they will be fine.
Larry
larrys40 is offline   Reply With Quote
