09-22-2017, 05:56 PM | #1 |
Pilot bearing
Having trouble getting the pilot bearing to budge. Any secrets or ideas??? Thanks
09-22-2017, 06:01 PM | #2 |
Re: Pilot bearing
Fill the cavity with grease. Use a shaft that is diameter of inside of bearing and whack it. Couple of applications of grease and it will pop out.
09-22-2017, 06:21 PM | #3 |
Re: Pilot bearing
You can also use a tap and thread the bearing, then use a big socket with some washers and a bolt to pull it out.
09-22-2017, 08:00 PM | #4 |
Re: Pilot bearing
That might work with a bushing, but would be a little bit difficult with a bearing! The grease method works or you can use a puller. There is a T shaped piece you can get behind the bearing and use a slide hammer. Auto supply store that loan tools should have a puller.
09-22-2017, 08:34 PM | #5 |
Re: Pilot bearing
Have to check for a loaner tool
09-22-2017, 09:02 PM | #6 |
Re: Pilot bearing
Now I'm hungry, going to make a PB&J |
09-22-2017, 09:05 PM | #7 |
Re: Pilot bearing
I take a bolt, the largest one I can put the head of- through the center. (OR grind bolt head to fit the hole). I use carraige bolts for this a lot.
Put apiece of something next to the bolt so it holds the bolt to one side. Put a socket or pipe over (larger than the bearing) Put washer or piece of steel with hole in it over that. Nut goes on the bolt, tighten to pull out bearing. Karl |
09-22-2017, 09:10 PM | #8 |
Re: Pilot bearing
In the same vein, I have heard that peanut butter works just as well as grease, but is not as messy. I tried it once, and it didn't work for me. Maybe I should have tried the third leg of the triangle!
09-23-2017, 03:26 PM | #9 |
Re: Pilot bearing
Tried grease and bread and didn't work. Borrowed a loaner tool and still won't budge. Any ideas? Thanks
09-23-2017, 03:30 PM | #10 |
Re: Pilot bearing
I have always used a slid hammer, but never had a problem getting one out. So not much help here. Is it a bushing style or actual bearing style?
09-23-2017, 03:45 PM | #11 |
Re: Pilot bearing
Bearing
09-23-2017, 07:04 PM | #12 |
Re: Pilot bearing
09-23-2017, 10:14 PM | #13 |
Re: Pilot bearing
Bought this off Amazon in 2013.Worked for me.59A engine with a bearing,not bushing.
09-24-2017, 02:21 PM | #14 |
Re: Pilot bearing
Cut the inner race with a dremel and small cut-off discs or a diamond bit. Then pull the retainer and balls out. Now you can run a weld bead inside the outer race, let it cool and it should shrink enough to pull out. Or split the outer race with the dremel... carefully!
09-25-2017, 07:39 AM | #15 |
Re: Pilot bearing
Did you try some penetrant, PB Blaster (not peanut butter)has always worked good on my rusty nuts.... Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
09-25-2017, 07:50 AM | #16 |
Re: Pilot bearing
Found this via Google: https://www.youtube.com/watch?v=28bSl4r1kwQ
Thread Tools | |
Display Modes | |
