Old 03-12-2021, 12:53 PM   #1
michael lange
Default Model b waterpump
I currently have 32 model b engine in my 30 A, The housing on the B water pump is cracked, I have a Model A head,and after doing some research, I believe I can buy an A pump and change out the B pump by installing the A head, BUT, I have been told by some, there are more water ports on the B head. Can someone with more experience than me, shed some light on my issue
michael lange is offline   Reply With Quote
Old 03-12-2021, 01:16 PM   #2
alexiskai
alexiskai's Avatar
Default Re: Model b waterpump
Just for clarification, the situation is:
  • You have a B engine with a B head and a B pump
  • The B pump is cracked
  • You have a spare A head lying around
  • You want to buy an A pump and then put the A head on the B engine?
Why not just buy a B pump?
Old 03-12-2021, 01:40 PM   #3
michael lange
#1 Hard to find #2 cost, obviously you have more money than me
Old 03-12-2021, 02:03 PM   #4
alexiskai
alexiskai's Avatar
The B block has additional steam holes, seen here
Old 03-12-2021, 03:10 PM   #5
California Travieso
Send a message via Yahoo to California Travieso
Michael,
Have you checked with the suppliers to see if any of them have an adapter? Perhaps someone on the HAMB may know where to get one.
David Serrano
California Travieso is offline   Reply With Quote
Old 03-12-2021, 04:14 PM   #6
Synchro909
Synchro909's Avatar
Originally Posted by California Travieso View Post
Michael,
David Serrano
https://www.snydersantiqueauto.com/P...l-a/water-pump
I don't always go the extra mile,
but when I do it's because I've missed my exit.
Old 03-12-2021, 04:39 PM   #7
California Travieso
Originally Posted by Synchro909 View Post
Synchro,
Secrets of Speed https://www.secretsofspeed.com/water-connections has one also for $58.
David Serrano
Old 03-12-2021, 04:42 PM   #8
alexiskai
alexiskai's Avatar
These are not the right adapters, these adapt the V8 pump to the model A head. SoS does sell an $85 adapter farther down the page that adapts the V8 pump to the B head. The V8 pumps are readily available. Only problem is you have to customize the pump to mount the B fan on the end of it.
Old 03-12-2021, 07:22 PM   #9
kawagumby
kawagumby's Avatar
My '31 has a late model ('39 casting) B engine with an A head and an A water pump. It works flawlessly and has over 2000 miles on it.
I have compared the A head gasket and B gasket and either will work fine IMO. Some say the copper type works best but opinions vary - and should be based on the head (A or B) design.
Tom
kawagumby is offline   Reply With Quote
Old 03-12-2021, 07:26 PM   #10
Charlie Stephens
By the time you buy a gasket to replace the head it may end up costing more. I would find an original B pump and have it rebuilt (try placing a "wanted" ad). Look for an original pump as I believe I remember people complaining about the castings on the reproductions. I am running a Model A police head (the one with the block "B" on top) on a Model B engine and never had any problems. If you decide to use the Model B pump be sure you don't buy a 1933-34 by mistake. The '33-'34 pump is shorter, see photo. If you run a Model A head on a Model B engine I believe you need to block the steam holes shown in Post #4.
Charlie Stephens
Old 03-12-2021, 07:45 PM   #11
mercman from oz
mercman from oz's Avatar
That is interesting in that there are two different lengths with these Model B Water Pumps.
The long one is 1932 while the shorter one is 1933-1934. Thanks for this helpful tip.
Last edited by mercman from oz; 03-13-2021 at 05:55 AM. Reason: Description change
Old 03-12-2021, 09:05 PM   #12
kawagumby
kawagumby's Avatar
Charlie Stephens
That shouldn't be the case; if you use the Model A head gasket with the model a head (which you should), those holes don't exist either in the gasket or the head. The gasket should seal off the holes - but to be sure, one could seal them first fairly easily.
Also notice that the B gasket width between cylinders (at valve side) is wider than the A gasket, so that would likely lead to premature failure if used with the A head. Both these gaskets are quality; the B is Felpro, the A is a Best product.
Here's a pic of the gaskets side-by-side:
Old 03-13-2021, 12:09 AM   #13
Charlie Stephens
Attachment 458219
I think you will find that the holes are close enough to the edge of the gasket that they will leak especially if the head was not located properly when it was machined. Also the wider contour of the Model A combustion changer doesn't adequately clamp the gasket over the steam holes. And finally you have unsupported gasket hanging into the combustion chamber.
Charlie Stephens
Old 03-13-2021, 12:16 AM   #14
Charlie Stephens
The '33-'34 pump was shorter because the radiator sloped back.
Charlie Stephens
Old 03-13-2021, 12:37 AM   #15
Charlie Stephens
Easy to spot at a swap meet due to the space between the grease fittings.
Charlie Stephens
Old 03-13-2021, 02:34 AM   #16
Dave Slater
Dave Slater's Avatar
Trevor. The long one is 32 and the short one is 33/34
Dave Slater is offline   Reply With Quote
Old 03-13-2021, 05:57 AM   #17
mercman from oz
Thanks for the correction. I have now corrected the details in my original Post 11.
Old 03-13-2021, 10:35 AM   #18
Bob Bidonde
Bob Bidonde's Avatar
Go ahead and run the Model A head on the B engine. You can use either the A head gasket or the B head gasket. The A head stock has a 4.2:1 Compression Ratio and the B has a 4.6:1 Compression Ratio. The difference is too small to matter.
Bob Bidonde
Old 03-13-2021, 10:58 AM   #19
Bob C
Vince has some good information on why you need to plug the steam
holes when mixing A and B heads and blocks.
http://www.fordgarage.com/pages/ABcy...asketguide.htm
Old 03-13-2021, 11:05 AM   #20
katy
katy's Avatar
Where is it cracked? maybe it could be repaired?
Play it again Sam.
