Old 01-30-2018, 12:58 AM   #1
KarlJS
KarlJS's Avatar
Default Radiator Hoses
I have a 1939 1/2 ton Ford truck, it has the original radiator and a 48-53 8BA Engine. I’m going to need radiator hoses (top and bottom). I know that the radiator and water inlets are different sizes. Wondering where to buy hoses and if anyone knows part numbers. Thanks
KarlJS is offline   Reply With Quote
Old 01-30-2018, 01:02 AM   #2
AlexLohmann1
AlexLohmann1's Avatar
Default Re: Radiator Hoses
This should help you. Mac's Auto Parts. I'll do some more checking in the morning. I may have some more sources.
https://www.macsautoparts.com/early_...tor-hoses.html
Sent from my SM-G955U using Tapatalk
AlexLohmann1 is offline   Reply With Quote
Old 01-30-2018, 01:05 AM   #3
AlexLohmann1
Old 01-30-2018, 01:07 AM   #4
Clem Clement
Clem Clement's Avatar
I have the same truck. Love it.
I have a aftermarket radiator so I had to chase around for the hoses. I think I got the longest NAPA had for the upper hoses. Maybe Carpenter for the bottoms. I deal a lot with Carpenter.
Your truck on the road?
Old 01-30-2018, 01:13 AM   #5
KarlJS
KarlJS's Avatar
Not yet. Just rebuilt transmission, now doing water pumps and radiator. Then brakes. Having fun learning something new.
Old 01-30-2018, 07:37 AM   #6
Clem Clement
good for you. These horse collar years-38/39 are fun. Not common. Parts are available.
Be sure to get the repro thin accessory book. It shows where the brake lines fit. I used Tyree's wiring harness. The green book has some good diagrams. Drake I think it is , sells the sliding rear window accessory. That solves the heat problem in the cab.
Holler if I can help.
PM me for a photo
Old 01-30-2018, 07:55 AM   #7
bosborn38pu
bosborn38pu's Avatar
This thread may provide some options to consider...
https://fordbarn.com/forum/showthread.php?t=218608
bosborn38pu is offline   Reply With Quote
Old 01-30-2018, 08:16 AM   #8
sunshine
sunshine's Avatar
my 39 pkup still had the metal upper hoses tho they were full of rusty holes .but a muffler shop was able to use them for patterns an make new ones .then I just used straight hose on both ends to complete the connection. My 47 pkup has the same steel pipes SUNSHINE.
sunshine is offline   Reply With Quote
Old 01-30-2018, 08:30 AM   #9
sunshine
sunshine's Avatar
Why don't you try C G ford parts in. Escondido CAl? 760 740 2400 great people to deal with call them they send you catalog SUNSHINE.
Old 01-30-2018, 08:49 AM   #10
marko39
drake sells water outlets for heads that are larger than the stock ones that allow you to use same size hose as your orriginals. i just got a set for my 8ba that i plan for my 39 car. they are stainless steel and of good quailty.
marko39 is offline   Reply With Quote
Old 01-30-2018, 08:53 AM   #11
AlexLohmann1
Might see if Michael Driskell has any of these or knows where to find them. Third Gen Automotive (931) 668-8540
Old 01-30-2018, 07:10 PM   #12
51504bat
51504bat's Avatar
I've got an 8ba in my '39. I was running flex hoses with a reducer to adapt down from the 1 3/4 inch '39 upper radiator top inlet to the 1 1/4 inch thermostat housing inlet on the 8ba. I think I still have the part number in the shop and maybe the hoses since I changed over to 1 3/4 inch thermostat housings that I got from Model Engineering (cheaper than Drakes and they had them when Drake was on back order) which allows me to run flex 1 3/4 inch flex hoses on both ends. I'll check for numbers next time I'm in the shop.
Old 01-30-2018, 07:13 PM   #13
AlexLohmann1
Sorry, I didn't read this request correctly. Ignore the posts above.
Old 01-30-2018, 07:41 PM   #14
51504bat
51504bat's Avatar
at a downward angle like a stock readiator)
I think these numbers are correct if you want to use flex hose:
Dayco 81231 1 3/4 x 1 1/2 x 13 1/4 then you will need a Dayco 769251 1 1/2 x 1 1/4 reducer
I have a complete set of flex hoses and reducers that no longer fit my truck since I changed to a Brass Works radiator (upper hoses come out straight not not at an angle like a stock radiator) and I'm using thermostat housings with 1 3/4 inlet not stock 1 1/4. I'm in Redlands and you can have them if you want. They don't have many miles on them. PM if interested.
Old 01-30-2018, 08:32 PM   #15
hotrodA
hotrodA's Avatar
Honest Charlie's, Chattanooga as well as Bob Drake have the outlets for the single diameter hose
hotrodA is offline   Reply With Quote
