Old 12-12-2019, 10:14 PM   #1
GB SISSON
GB SISSON's Avatar
Default Sheared starter drive bolt
I went down to the shop after work to do the usual battle with this new to me AA cut down truck. Before I could deal with the issues I wanted to address The starter spun but didn't turn the flywheel... So I started it with the crank..... But I want electric start. I pulled the starter and found a sheared off bolt. My wife was due home in 20 minutes ... A bolt had sheared off in the drive. 12 v conversion done by PO ,,, any surprise?> Looking at the green bible I see the drives are similar. I have a half dozen Flathead v8 starters here in a heap. Are the bolts the same? Do I* need to order some starter drive bolts or do I already have some? Wife and I in the middle of dinner now............
'47 1/2 ton pickup next project, '47 one ton panel 99% stock nearing completion, '47 2 ton with 8ba and 9' script stakebed, '46 1/2 ton woodie project,'59 F350 9' flareside pickup with cummins 6at. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 12-13-2019, 12:15 AM   #2
jw hash
jw hash's Avatar
Default Re: Sheared starter drive bolt
the Model A starter drive used 5/16" bolts and they break all the time. the V8 starter drive uses 3/8" bolts, I run the V8 drives and have not broke a bolt in many years. check and see what bolts you have. if you are running a 6 volt starter on 12 Volts it is going to engage hard and that is hard on the drives and or the bolts.
jw hash is offline   Reply With Quote
Old 12-13-2019, 09:15 AM   #3
GB SISSON
GB SISSON's Avatar
So, a V8 drive will slide onto the A starter shaft? No redrill or tap?
Old 12-13-2019, 09:55 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
With 3/8" diameter Bendix bolts properly installed with the special lock-washers and a new spring, I have been running 12V in my Coupe with a stock starter motor for many years without issue.
Bob Bidonde
Old 12-13-2019, 12:20 PM   #5
GB SISSON
GB SISSON's Avatar
Thanks! Just came in from the shop. Direct replacement. Wish all repairs and modifications were that straight forward. That starter drive interchanges from '28-'53. The year my mom was born until the year that I was born!
Old 12-13-2019, 12:27 PM   #6
Bob C
Be sure to get the broken bolt out of the flywheel housing.
Bob
Thread Tools
Display Modes
