11-22-2013, 05:50 PM | #1 |
watts, ohms, volts oh my???
I will now show my lack of knowledge in the finer points of electricity. I have an older 6 volt defroster fan that draws 2 amps at 6 volts and runs fine.
I bought a voltage reducer from Napa but that didn't help at all. What can I put together that would reduce the voltage. I did find a variable resister that is about as big as a snuff can that I could make work but just too big. Many thanks in advance. ( I do know how to solder and cut wires. lol) Fourdy |
11-22-2013, 05:51 PM | #2 |
Re: watts, ohms, volts oh my???
Probably should have said that I need to reduce from 13 volts.
Fourdy |
11-22-2013, 06:38 PM | #3 |
V=I x R so say it draws 2 amps. 6 volts = 2 amps x Resistance Resistance = 3 ohms.
The size of resister required will be: Watts = Volts x Amps so 6 x 2 = 12 watts A 3 ohm 12 watt resistor should work. Below is a 3 ohm 100 watt Resistor http://www.ebay.com/itm/3-Ohm-3R-100...item5ae310ada9 |
11-22-2013, 06:46 PM | #4 |
With a resistor inline, your still going to supply 12 volts to the fan motor...just less amperage.
You have to sink the resistor to ground to split the voltage. I/e 12v------resitor to ground(where resistor is tied to 12v supply)------heater motor. I've a voltage reducer in my '42...big round ceramic looking thing, and 12v in, one lug to ground and 3-4 outputs. |
11-22-2013, 07:19 PM | #5 |
Mike B>>>your still going to supply 12 volts to the fan motor>>>
Sorry to disagree, Mike. With the aforementioned single 12 W resistor is series with the 12 watt motor, half the 12v is dropped across the resistor (6 volts), and half across the motor(6 volts). That is, 6v drop across each. What you apparently have is the equivalent of a multi-tap potentiometer. The full 12 volts is dropped across the circular length of a very hi-power resistor that has individual taps along its length for various voltages between 0 and 12 volts. The problem with a potentiometer is that it must draw a current far exceeding those currents required by devices connected to the taps in order to get the desired tap voltage. Jack E/NJ |
11-22-2013, 11:17 PM | #6 |
No...it's a series circuit, the resistor will drop the amperage, but the voltage will remain the same. |
11-23-2013, 12:19 AM | #7 | |
You are never to old to enjoy your childhood. Forty1fordpickup on the HAMB. |
11-23-2013, 01:02 AM | #8 |
Okay...let's simplify this, or bring me to my senses
12v...1K resistor...device (bulb/motor/etc.) 12v....1k resistor....1 K resistor...Device 12 v...1K resistor...1K resistor...1 K resistor...Device In each of the above series circuits, how much voltage is applied to the device? |
11-23-2013, 04:07 AM | #9 |
Very simple and easy to do, Get a blower resistor for a 70's GM. They have 3 or 4 taps out put just find the one closes to 6 Volt. I used one in my 51 F-1 that had 7 volts. It does have to be in the air stream to cool it but will work very well. I used a hole saw to mount the resister in the bottom of my heater so fan motor kept it cool. |
11-23-2013, 05:36 AM | #10 | |
The fan, when working, is the same as a 3 ohm 12 watt resistor. If you place another 3 ohm 12 watt resistor in series, each will have the same voltage drop. Kirchoff's law states that the sum of the voltage drops, minus the supply voltage will equal zero. Please note we are talking about ACROSS the resistor and ACROSS the fan. If you put together the circuit; battery, resistor, fan, and measure across the resistor you will read 6 volts. If you measure across the fan you will measure 6 volts. 6 volts plus 6 volts -12 volts (battery) = zero. Clear as mud?
11-23-2013, 05:39 AM | #11 | |
If we assume 1k for the device, 12v...1K resistor...device (bulb/motor/etc.) - across each part 6v 12v....1k resistor....1 K resistor...Device - across each part 4 volts 12 v...1K resistor...1K resistor...1 K resistor...Device - across each part 3 volts
11-23-2013, 06:55 AM | #12 |
VanWinkle's Law: Wamps + Vohms/Resistors = zzzzzzzzzz
11-23-2013, 09:46 AM | #13 |
As the Kingfish once said, "the atom is made up of protons, neutrons, fig newtons and morons."
11-23-2013, 10:11 AM | #14 |
Fourdy
Randy Rundle has a resistor for fan motors. You might call him and ask about it. I don't know how well it will work or how long it will last but it is a design that should work. http://www.fifthaveinternetgarage.co...counter_2.html |
11-23-2013, 11:46 AM | #15 | |
11-23-2013, 02:14 PM | #16 |
Assuming the impedance or resistance of the heater motor doesn't change, a 6v motor will draw 2x the current at 12v and have to dissipate 4x the power or wattage. A 6v motor will definitely run faster at 12v but may overheat and fry. A dropping resistor like that recommended by 12/21/1975 above is recommended to avoid this possibility.
Jack E/NJ |
11-23-2013, 02:27 PM | #17 |
What DEC211975 said is correct. 3 ohm 12 watt. But that 12 watt resistor would be very hot. Use a wire wound 24 watt min.
11-23-2013, 02:31 PM | #18 |
Is there any reason why the 6 volt heater motor can't be run on 12 volts (just making it run faster)?
11-23-2013, 03:02 PM | #19 |
Post #16 is a response to post #18
Jack E/NJ |
11-23-2013, 04:00 PM | #20 |
