Old 12-08-2019, 09:08 PM   #21
dumb person
dumb person's Avatar
Default Re: What did I just buy?
Originally Posted by GB SISSON View Post
But then I'd have to come up with a title.....And in second gear it's about all I can handle. So far it has one brake. The right rear. Oh, and the band parking brake. No rods to the front. Whatever........
You can't title it as a farm vehicle? Not sure tractors had VINs. I've never seen one with one.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 12-09-2019, 10:46 AM   #22
katy
katy's Avatar
Could I just wire one up from something else to see?
It's worth a try. If running an original coil the proper value is .22 mfd. .47 mfd is a common value and I would guess it would work.
Don't go away mad, just go away.
Old 12-09-2019, 11:22 PM   #23
GB SISSON
GB SISSON's Avatar
I'm on a 12 v coil running through a ceramic resistor on the firewall. I have some early v8 condensors. What do I wire to and do I need to remove the condenser that's in there? Thinking the condenser body screws to ground and the wire connector to movable point, stationary point????? Oh and I pulled the manifolds off today after work and flattened them on my 3' edge sander. Found a set of manifold gaskets hanging on a nail and that part is done. Sealed up tight. One more thing..... Here's a quick slideshow of my last project.
https://spark.adobe.com/video/M0ynvLlPj2GCC
'47 1/2 ton pickup next project, '47 one ton panel 99% stock nearing completion, '47 2 ton with 8ba and 9' script stakebed, '46 1/2 ton woodie project,'59 F350 9' flareside pickup with cummins 6at. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 12-10-2019, 10:55 AM   #24
katy
katy's Avatar
Remove the original condenser, attach replacement between movable points arm and ground.
Old 12-10-2019, 01:16 PM   #25
Purdy Swoft
Purdy Swoft's Avatar
A modern condenser can be attached to the firewall , or the coil bracket for ground . The pigtail wire on the modern condenser should be connected to the switch side of the coil . The switch side of the coil will have a red wire unless the wiring has been changed to a different color wire than was originally used . Where the condenser mounts is the ground and must be clean and tight or it won't run . This puts the condenser in an easy spot to remove and replace whenever necessary. I have run a modern condenser mounted and connected in this manner for over twelve years . An old model A guy showed me this back in 1960 and it is plenty close to the points and has worked perfectly for me . The condenser will run cooler and last longer . The modern condenser will be easy to remove and replace when mounted in this manner . I've been told that the original condenser must be removed from the distributor when this setup is used . I use the modern condenser that is offered with the V8 points setup . The last condenser that was used with V8 Fords can usually be found locally . The condenser doesn't know the difference between 6 or 12 volts because I have used them both ways . This is about as simple as it can get and can easily be reversed .
Old 12-11-2019, 07:12 PM   #26
GB SISSON
GB SISSON's Avatar
Excellent! I will give it a try tomorrow after work. Thank you very much.
