Old 12-08-2019, 05:02 PM   #1
RalphM
RalphM's Avatar
Default Radiator neck pliers?
Trying to get the outlets on my 35 radiator round again. I did a search online and canít come up with anything because all the new radiators are plastic and aluminum, and the tools for them are completely different.
Does anyone know where I can get the old style pliers for reshaping the outlets on radiators?
Specifically looking for one that will do one and a half inches.
RalphM is offline   Reply With Quote
Old 12-08-2019, 05:11 PM   #2
glennpm
glennpm's Avatar
Default Re: Radiator neck pliers?
Would a tail pipe expander work? It would be the insertion depth that I would wonder about.
https://www.harborfreight.com/Medium...der-63703.html
Glenn
Old 12-08-2019, 05:15 PM   #3
petehoovie
petehoovie's Avatar
These aren't "old style" but they will probably do the job >
"We shot our way out of that town for a dollar's worth of steel holes." - from 'The Wild Bunch' - 1969
Old 12-08-2019, 05:20 PM   #4
RalphM
RalphM's Avatar
The ones I remember when I used to work at a radiator shop when I was a teenager have a 90į Bend at the end and it goes in the radiator outlet to shape it properly. There were serrations on the 90 ‘ end but other than that look like a regular pair of pliers.
Old 12-08-2019, 05:29 PM   #5
petehoovie
petehoovie's Avatar
Like these? >
https://www.ebay.com/itm/VINTAGE-UTI...oAAOSwKS9d5~fL
or these? >
https://www.ebay.com/itm/2x-Vintage-....c100752.m1982
Old 12-09-2019, 02:21 AM   #6
RalphM
RalphM's Avatar
No nothing like that. They kind a look like these in shape only but the ones I’m thinking of are metal and there are serrations on the outside of the bent area and when you squeeze the handle the jaws move apart. This will get the outlet round from the inside out.
File Type: jpg 03A0884D-F3B4-439D-9934-8FF3EBE7345F.jpg (4.9 KB, 27 views)
Old 12-09-2019, 04:13 AM   #7
deuce lover
deuce lover's Avatar
Would this tool work?
https://www.ebay.com/itm/Tail-Exhaus...e/270637622265
deuce lover is online now   Reply With Quote
Old 12-09-2019, 04:33 AM   #8
DavidG
DavidG's Avatar
I use progressively larger wrench sockets.
Old 12-09-2019, 05:12 AM   #9
Alaska Jim
Alaska Jim's Avatar
Ralph, I have a set of tail-pipe expanders like duce lover showed a link to. they come in several sizes. I have used them on radiators before, and they work fairly well, but you have to watch that you don't "dis-figure the flare " at the mouth of the outlet.
Alaska Jim is offline   Reply With Quote
Old 12-09-2019, 01:52 PM   #10
RalphM
RalphM's Avatar
Yeah I guess I’ll have to use a muffler pipe expander, I just remembered a tool that was a whole lot different when I used to work at a radiator shop as a teenager.
Old 12-09-2019, 02:28 PM   #11
petehoovie
petehoovie's Avatar
Like these?
Old 12-09-2019, 02:37 PM   #12
KiWinUS
KiWinUS's Avatar
Pete I believe those are battery terminal pliers.
Old 12-09-2019, 02:44 PM   #13
petehoovie
petehoovie's Avatar
Yes, they are...But they kinda match Ralph's description...Just have to find one that opens wider.
Old 12-09-2019, 05:09 PM   #14
Viv W
David's idea to use progressively larger sockets does work. I recently did this on a squashed STEEL breather pipe for my Nash and it worked a treat, so with a brass radiator pipe it should work even easier.
I used the socket the wrong way around, fitting a 12 inch extension from the nut/bolt end, to make it easier to hold the socket and also putting the square drive side into the pipe first. Doing it this way around makes it easier as it then has a sort of natural taper going into the pipe. Once you have expanded the pipe as close to the original size, you can then use the socket inside the pipe as a sort of "DOLLY" while you use a small hammer to plenish out any dents IF necessary.
Viv W is offline   Reply With Quote
Old 12-10-2019, 12:58 AM   #15
RalphM
RalphM's Avatar
Like these?
Yes, like that!
Old 12-10-2019, 01:47 AM   #16
petehoovie
petehoovie's Avatar
https://duckduckgo.com/?q=battery+te...ages&ia=images
Old 12-10-2019, 11:37 AM   #17
Bob C
Is this what you want?? http://www.johnsonmfg.com/2015/410.HTM
Old 12-10-2019, 01:41 PM   #18
Scotty's 52 F3
Scotty's 52 F3's Avatar
Found this slick home built tool to do exactly what the OP needs. https://youtu.be/v5WS7UhR25I
Scotty's 52 F3 is offline   Reply With Quote
Old 12-10-2019, 04:19 PM   #19
RalphM
RalphM's Avatar
Originally Posted by Bob C View Post
Thatís it! Iíll take the entire set !
Old 12-11-2019, 03:26 PM   #20
glennpm
glennpm's Avatar
The Youtube link that Scott posted in message #18 is great. I like the use of the muffler clamp backer. I made this tool to make a "bump" for a trimmed SS radiator pipes using a very old pair of vice grips.
I marked a line around the pipe/tube OD and then made a few passes all the way around, The trick is to make the "roll" a little at a time.
Glenn
