Old 09-08-2019, 09:03 AM   #1
phil pavicich
Default 34 front engine mount /water outlet
Are there any suppliers of new castings for the front enginemount / water outlet for 34 engine mine have both corroded away , thanks in advance
phil pavicich is offline   Reply With Quote
Old 09-08-2019, 09:28 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 34 front engine mount /water outlet
Not reproduced to my knowledge.The Ford Store in San Dimas,CA might have a nice original pair available.Maybe a member here also.
Old 09-08-2019, 09:52 AM   #3
Kerk
I have a pair but they are not marked ! I thought they were 35 when I bought them but they were too Narrow when mounted on my engine so maybe ethey are 34/34, You are wlecome to have them for the 35 dollars I have in them plus the S&H cost.. They are useable but have some rust at the outlets. kerk
Kerk is offline   Reply With Quote
Old 09-08-2019, 10:14 AM   #4
Charlie ny
Phil,
I have some....they are originals. I machine off the rotted water snout and
and counter bore into the now solid iron. I renew the proper length snout with an iron sleeve that is step turned and pressed into the orig casting. In addition to the press fit on the sleeve I use JB long setting epoxy. No issues, some Barners are using them. I
would certainly welcome any comment either way.
Charlie ny
[email protected]
Old 09-09-2019, 07:51 AM   #5
phil pavicich
Originally Posted by Charlie ny View Post
Phil,
Charlie ny
[email protected]
Thanks Charlie , me being a machinist i will do the same to mine , thanks for the info cheers Phil
Old 09-08-2019, 01:49 PM   #6
bobH
Charlie's repair is GOOD.
I also have a pair that are available. Some rust-out on ends, but still usable. They have the part # cast on.
bobH is offline   Reply With Quote
Old 09-09-2019, 10:36 AM   #7
DavidG
DavidG's Avatar
I recommend one additional step after the repairs have been completed, namely powder coating inside and out. If your powder coating source doesn't have the Ford engine green color you can always add that over the powder coating with a rattle can.
