02-12-2018, 11:40 AM | #1 |
Motorcraft Oil Filter FL-14
Have a valve cover mounted oil filter on a 31 Slant.
Has a Motorcraft FL-14 oil filter. Will a NAPA 1515 fit? Unable to locate the Motorcraft is a very old number. Thanks |
02-12-2018, 12:03 PM | #2 |
Re: Motorcraft Oil Filter FL-14
Must really be an old number, I looked in a 1975 filter catalog and it's not listed.
Bob |
02-12-2018, 12:12 PM | #3 |
I have the same setup as you Dave and I use NAPA Gold 1068
02-12-2018, 12:51 PM | #4 |
Are you sure it is not a FL-1A? I am building an engine with that set up and it came with a Motorcraft FL-1A. That is a common filter you can get just about anywhere.
02-12-2018, 01:14 PM | #5 |
Fram PH8A
02-12-2018, 01:42 PM | #6 |
02-12-2018, 02:12 PM | #7 |
Don't use Fram as they are junk inside. All paper and hot glue.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
02-12-2018, 02:22 PM | #8 |
Wix 51515
02-12-2018, 02:55 PM | #9 |
Thanks NAPA 1515 same as WIX
02-12-2018, 04:39 PM | #10 |
Wix is one of the Best and they make many for other companies.
02-12-2018, 04:44 PM | #11 |
02-12-2018, 05:12 PM | #12 |
They may be leading a leading sales manufacturer but are far from a leading quality producer. They are big because they are cheap and sold by every discount place in the world. I used them as a youngster because my family did but I stopped when the inside collapsed on a race motor many years back. Now Ionly use OEM and Wix. I have used Napa Gold in a pinch in engines I'm not that fussy about.
02-12-2018, 05:17 PM | #13 |
These are all interchangeable and will work on the after market side cover oil filters for the Model A:
Pennzoil PZ-1 Fram PH8A AC PF-2, PF-20 Motocraft FL-1A3 Napa 1515 Lee LF-2 Tom Endy |
02-12-2018, 05:58 PM | #14 | |
02-12-2018, 06:02 PM | #15 |
OOPS F-1A
1515 was correct NAPA GOLD Last edited by barkleydave; 02-13-2018 at 09:16 AM. |
02-12-2018, 06:15 PM | #16 |
On another auto site several guys with a lot more time than I have cut apart filters from all the manufacturers. You would be amazed at the difference in construction. I'm sure there are dozens maybe hundreds of threads knocking Fram filters. I suppose they do the job, but for a few extra bucks why not buy the best, WIX.
02-12-2018, 09:54 PM | #17 |
Is it possible it could be a Motorcraft FL144 that was used on Jeep, Willys, Case, Ford, Hudson, Massey? Thought a number 4 may have worn off.
02-12-2018, 10:51 PM | #18 |
They spend millions in advertising and sponsorship.
If you look up oil filters you will see what a Fram looks like inside.
02-13-2018, 09:18 AM | #19 |
I've used many, many Fram filters over the last 50 years or so and never had a problem w/any of them.
BTW, are Kralinator oil filters still made? If so, does anyone use them?
02-13-2018, 10:56 PM | #20 |
I have also used fram for years with no problem, bottom line use what ever filter you want too it's your car Bob
