Old 08-10-2012, 09:35 PM   #1
bjk2dr
Default Sticky piston rings
I'm thinking I might possibly have some stuck piston rings on a running 1940 ford v8. Any ideas I could try short of engine removal. Basically a quite smooth running motor. Smokes a little and compression is lower on a couple cylinders.
Thanks
bjk2dr is offline   Reply With Quote
Old 08-10-2012, 10:49 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Sticky piston rings
Remove the plugs and add auto trans fluid in equal parts to the cylinders you want to unstick. You need to use enough to cover the piston. Add more again in a couple of days. Drain the oil after a week or so and see if that doesn't free them up. A compression check before starting can tell a bunch. Take a reading and then add some oil and take another, if there is change it usually is leaking past the rings.
Old 08-11-2012, 11:17 AM   #3
KCguy
I've had great results with Marvel Mystery Oil in every engine I've used it in. I add to gas at every fill up and occasionally add to oil.
KCguy is offline   Reply With Quote
Old 08-11-2012, 07:54 PM   #4
bjk2dr
Thanks, will give it a try.
