Old 07-17-2019, 07:07 PM   #1
Tom in SW VA
Tom in SW VA's Avatar
Default Water temperature sending unit
Where can I get a water temperature sending unit for a 37 21-stud V-8?
Thanking you in advance.
Tom
Tom in SW VA is offline   Reply With Quote
Old 07-17-2019, 07:35 PM   #2
paul2748
paul2748's Avatar
Default Re: Water temperature sending unit
Dennis Carpenter??
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 07-17-2019, 08:03 PM   #3
Terry,OH
Terry,OH's Avatar
From 35-39 the water temperature is measured by a gauge as part of the gauge is the sending unit, they are one assembly. Photo below is 36 temperature gauge.
Old 07-17-2019, 08:14 PM   #4
v8fordman
v8fordman's Avatar
Terry,OH is correct but a '35 and '36 will not fit your original instrument cluster if you are still using it. '37-'39 are the same but the face is different. I have originals or rebuilt ones by Rudy Faultermeir. I would suggest an original since the fluid in rebuilt ones most likely will fade.
v8fordman is offline   Reply With Quote
Old 07-17-2019, 08:22 PM   #5
51504bat
51504bat's Avatar
Williamson's Instruments will put a new bulb on your old gauge.
https://williamsons.com/
Old 07-17-2019, 11:31 PM   #6
deuce lover
deuce lover's Avatar
The Early Ford Store (San Dimas,CA)has several NOS in stock
deuce lover is online now   Reply With Quote
