Old 11-12-2018, 10:41 AM   #1
rer_239
rer_239's Avatar
Default 3 or 5 brg camshaft
did an engine made in nov 1928 have a 3 or a 5 brg camshaft. i bought an incomplete block that didn't have a cam.
thanks
dick
rer_239 is offline   Reply With Quote
Old 11-12-2018, 11:43 AM   #2
Jim Brierley
Default Re: 3 or 5 brg camshaft
If your block was made for the 5 bearing cam, it would have obvious 5 bearing webs. If for the 3 bearing it would just have the same 3 as the crank has. There were three different 5 bearing cams. The first had all 5 bearings finish-ground to the same size, the second had the 2 intermediate bearings also finish-ground but to a smaller diameter and the third they were rough-cut. This was to make it easier and quicker to install the cams in the 3 bearing block.
Old 11-13-2018, 09:23 AM   #3
rer_239
rer_239's Avatar
looks like i have a 3 brg. block.
thanks
dick
Old 11-13-2018, 11:09 AM   #4
Purdy Swoft
Purdy Swoft's Avatar
The three bearing cam will also work in the five bearing block .
Old 11-13-2018, 12:26 PM   #5
Jim Brierley
And vice-versa.
Old 11-14-2018, 01:29 AM   #6
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Originally Posted by Jim Brierley View Post
And vice-versa.
I hope so, cause I put a five in a three.
Old 11-14-2018, 04:03 PM   #7
Pete
Pete's Avatar
I too, put a 5 in a 3.
Old 11-14-2018, 10:46 PM   #8
hardtimes
hardtimes's Avatar
Hey Pete,
Looks like a 5 in a 5 that is/was a three !
Pretty tricky !
How durable is that ?
It appears to be welded in at the base. Is that so, or just how do you keep it in place ?
Old 11-14-2018, 11:21 PM   #9
Pete
Pete's Avatar
Originally Posted by hardtimes View Post
Hey Pete,
Pretty tricky !
The aluminum blocks are pinned and bolted in and then align bored. The cam runs directly in the aluminum. Full pressure oiled. It lasted 2 seasons on the circle track and a year of just driving around with an occasional hill climb.
The cam was fabricated from an original A cam with welded up lobes and sleeved up journals. .488 lift.
As far as I know it I still running in a vintage sprint car.
Old 11-15-2018, 03:29 PM   #10
hardtimes
hardtimes's Avatar
Hey Pete,
You do nice work, indeed !
Aluminum block, hm must be a modern age banger block, eh ?
Wish you were closer, I’d have you look at B aluminum block, to work your magic on !
It has a 5 bearing ‘28 cam in it also
I’m not good at this and most likely get the hp/performance like it is capable of, as I know you would get.
A friend got 155 on his block, on a dyno, he tells me!
I’d bet $ you could get more !!
I’ve heard that it can work with 200, but that seems like a pipe dream, eh.
Old 11-15-2018, 03:42 PM   #11
Pete
Pete's Avatar
Hey Pete,
I was referring to the aluminum block bearing housings.
It takes more than 200 to win the Antique Nationals.
Old 11-15-2018, 11:00 PM   #12
hardtimes
hardtimes's Avatar
Yup, my mistake. Had aluminum on my mind !
