06-02-2018, 06:06 PM | #21 |
Re: Battery Disconnect
Seat riser here also and the switch breaks the ground not the hot side.
06-03-2018, 03:33 PM | #22 |
according to Ron Francis put the battery disconnect on the positive wire if you have any electronics in the circuit I guess like a C.B. or inverter,they could be damaged if you have a failure in a ground.page #104 Ron Francis catalog.
06-03-2018, 10:56 PM | #23 |
Mine is on seat riser on ground cable. I have 12v neg. ground.
