Old 08-23-2020, 08:57 AM   #1
Topher5150
Default 46-48 interior panel
I have a 47 Ford club coupe, long door, that other than a couple of pieces of trim didn't come with an interior. The kick panels and door panels should be easy enough to figure out. I just need some help with the panel in the back, how far does it go, where and how does it meet with the headliner etc....If you have pics, or links that would be great to.
Topher5150 is offline   Reply With Quote
Old 08-23-2020, 01:23 PM   #2
oldford2
oldford2's Avatar
Default Re: 46-48 interior panel
This may not help because it is a sedan not a coupe. The headliner material comes down behind the hand strap and behind the gray/blue material. In the old days it was called an ankle strap. John
oldford2 is offline   Reply With Quote
Old 08-23-2020, 04:24 PM   #3
Topher5150
It definatly points me in the right direction. So there's the cut out for the window, follows, and attaches to the wheel well down to the floor, and then stops just behind the seat seems simple enough
Old 08-23-2020, 07:44 PM   #4
51woodie
51woodie's Avatar
I have a pic from my 46 Coupe that I will post later
51woodie is offline   Reply With Quote
Old 08-23-2020, 09:19 PM   #5
51woodie
51woodie's Avatar
This is from my '46 super Deluxe Coupe. I hope it helps.
Old 09-01-2020, 01:49 PM   #6
Topher5150
would this book have part numbers, and assembly drawings of interior parts?
Old 09-12-2020, 02:43 PM   #7
Bob C
That book would list the part numbers but even then it may be hard to get what you want. At $30 a drawing you want to be sure you are going to get something you can use.
Old 09-13-2020, 02:38 PM   #8
supereal
supereal's Avatar
$52 at C&G as Item V-44. Sounds pricey, but worth it. 800/266-0470.
supereal is offline   Reply With Quote
Old 09-13-2020, 03:11 PM   #9
TJ
TJ's Avatar
From Cartouche you can order a complete pre-cut interior panel kit for $319 for those that want to do their own upholstery.
Old 09-19-2020, 10:14 PM   #10
1oldtimer
1oldtimer's Avatar
I use the EFV8 club book.
1oldtimer is offline   Reply With Quote
Old 09-19-2020, 10:22 PM   #11
1oldtimer
1oldtimer's Avatar
BTW, my super deluxe without the rear arm rests.
Old 09-20-2020, 11:00 AM   #12
reagen
ya boy
reagen is offline   Reply With Quote
Old 10-14-2020, 04:11 PM   #13
Topher5150
So is this what the back panels end up looking like?
Old 10-19-2020, 01:06 AM   #14
1oldtimer
1oldtimer's Avatar
That looks like it.
