10-26-2018, 08:22 PM | #1 |
Opinions wanted on 3.78 in a Columbia
Right now I have 3.54 gears in my '36 5 window. A friend has a '36 3 window with a 4.11 and a Columbia. We drove both cars just a few minutes apart. I run about 3000 rpm at 60 mph. His car did not have a tach but the engine speed sounded about the same at 60 mph.
Mine just sounds like it needs another gear at road speed. Around town I am fine with the stock 3-speed. Would the 3.78 be a good intermediate selection for interstate travel? |
10-26-2018, 08:28 PM | #2 |
Re: Opinions wanted on 3.78 in a Columbia
Not sure what you are asking but going from a 3.54 to 3.78 would be the opposite of what you want. I think 3.78 and a od columbia would be perfect.
I have a 3.78 with a 36% mitchell od on the truck. Rebuilt engine. Runs swell at 60-70 at around 2-2.500 (Im ear guessing as I don't have a tac. it's not winding out anyway) Plenty of rpm left if the engine hp could pull it to go more. |
10-26-2018, 08:33 PM | #3 |
Sorry, yes forgot to mention that I am asking about installing a 3.78 in a Columbia for improved highway driving.
10-31-2018, 11:52 AM | #4 | |
Steve, My comments about converting your '36 to a Columbia might be a little off topic, however, I thought I would share my experiences with you. My '36 was dead stock when I bought it in '52 from the original owner. It had the early style of Columbia under it with 3.78 gearing. I found the original controls to be very user unfriendly so I converted the unit to a '42-48, I retained the original drive-line and center section. I used the late model electric over vacuum controls which made shifting much easier. Most people are under the impression that the '42-48 Columbia's have to be cut down to fit under a '36, the '42-48 is less than 2" wider than a '36, however the added width does not present a problem. I used '37 radius bars bolted to the '36 torque tube and axle housing and a '42-48 rear spring and shocks.. My axle is actually a '48 so it had a panhard (sway bar) incorporated into the axle housing. My front end is a '41 axle, dropped 2", tube shocks front and rear. Brakes are '42-48, steering gears are '40 on a '37-39 frame mount. The car handles very nicely at speed, have had it over 100 mph on many occasions. Feel free to PM me if you have any questions about how my car is set up.
Bill.... 36 5 win cpe |
10-26-2018, 08:37 PM | #5 |
I probably misunderstood. I think that's a winning combo. Smarter folks will add, but that's not a bad plan.
10-26-2018, 08:43 PM | #6 |
10-26-2018, 08:48 PM | #7 |
JSeery, he's asking about putting a OD in. OD's are pretty nice for the highway getting rpms down for long distance. Only have to engage once you are doing 60-70 at higher rpms.
What I get from it. |
10-26-2018, 08:51 PM | #8 |
I see! Then a 3.78 with an OD added would be a great combo IMO, LOL
Asleep at the wheel (keyboard) again! Guess the title was throwing me. |
10-26-2018, 09:01 PM | #9 |
Thanks everyone, yes Tinker has expressed my poorly explained desires, just trying to get more highway speed combining the 3.78 with a Columbia.
10-26-2018, 09:08 PM | #10 |
Ya probably my bad too for not reading the title as much as I did with the context within. hahahaha but i digress..
10-26-2018, 09:21 PM | #11 |
I have a Columbia in my 40 with 3:78 gears . Bone stock 221 flathead and it works fine.
10-26-2018, 09:30 PM | #12 |
What kind of highway speeds are you comfortable at? 65-70?
10-27-2018, 09:33 AM | #13 |
No one mentioned the shifted ratio of the Columbia
A 3:78 Columbia shifts to 2:78 A 4:11 Columbia shifts to 2:97 Either one gives a good Highway final rear gear when shifted. The engine/trans combo and how you use the car without engaging the Columbia is the question. Right now we have two cars with Columbia overdrives, one is using a mildly hopped up 21 stud V8 using the 4:11/2:97 combo. The other is using a 55 Dodge Hemi, mildly hopped up, using the 3:78/2:73 combo. Both cars have 1:1 final drive in the transmissions. They are both currently under construction, I'll know more in the Spring.
Early Ford Lock & Key Service https://www.fordbarn.com/forum/showthread.php?t=46583 |
10-27-2018, 09:38 AM | #14 | |
I want a Columbia and will add one to the car someday. |
10-27-2018, 10:37 AM | #15 |
I have always preferred the 3:78 with or without an overdrive. In the Midwest we have a lot of hills - some steep. The 3:78 provides good "traction" when pulling away from a dead stop and will also allow the engine comfort at cruising speeds.
Many guys ask: "Can the car comfortably do 65 - 70 MPH with a Columbia and a 3:78?" A: Sure it can. I ask: "Do you have a stock suspension and brakes?" "If so, are you ready to stop as quickly as may be necessary at those speeds?" "Can you quickly maneuver out of the way of the idiot in the BMW that just swerved directly in to your lane"?
10-27-2018, 11:45 AM | #16 |
Kube,
I am currently working on converting to hydraulics, but that is a different thread. The rest of the suspension will be stock. I am also working on converting from the '36 steering to '37 steering. I do have all of those parts, just no time. I do have a friend here in Denver that does build Columbias and I do already have the right side housing, but again, time and money. Thanks Steve |
10-27-2018, 01:11 PM | #17 |
I have a stock 39 flat motor with a T170 4 speed and a Columbia with 3.78 R&P. I've been up to 80mph with more to go but the bias plys were doing their wiggle dance and I didn't want to end up in the ditch. Lincoln brakes up front with 39 juice in the back. I did the conversion after some freeway driving with the stock 4.11 and 3 speed crashbox. I found it to be scary trying to keep up with modern traffic, with the motor revving so high. MUCH better now. Looking forward to some Diamondbacks in the future.
Considering some discs for the front, but not before new tires. Last edited by johndee138; 10-27-2018 at 01:20 PM. Reason: additional info |
10-27-2018, 01:32 PM | #18 |
Thanks JohnDee. I will look into some 3.78s when I can afford them. I do see a set on ebay right now but not ready to spring for them.
10-27-2018, 02:34 PM | #19 |
10-27-2018, 09:04 PM | #20 |
My '40 coupe and pickup both have 3.78s with columbias with warmed up flatties.
They work good on the freeway at 65 - 70 even up hills. I love 'em! |
