Old 12-21-2018, 04:34 PM   #1
Paps31
Paps31's Avatar
Default Serial number size
Odd request, but bear with me.
Iím planning on restamping my block (needs to pass VIN inspection to get a Kentucky title). I want to get it done when I get back from holiday travel, but I forgot to triple-check the size of the very faint numbers that currently exist on the engine.
I want to say 1/4Ē, but I want to be sure before I order from McMaster-Carr.
Anyone feel like running out to their garage with a ruler?
Thanks in advance.
Paps31 is offline   Reply With Quote
Old 12-21-2018, 05:56 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Serial number size
Depending on date of manufacture some of the numbers have a different font from normal number stamps ---- there are pictures in the service bulletins
Old 12-21-2018, 05:59 PM   #3
rfitzpatrick
I'll be darn! Mine is 1/4 inch. Fla never even came out to see
rfitzpatrick is offline   Reply With Quote
Old 12-21-2018, 06:15 PM   #4
JOHN CT
JOHN CT's Avatar
If you’re not going for judging. I wouldn’t think any size as long as someone can read it and Without leaning on the fender.
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 12-21-2018, 06:25 PM   #5
F.M.
Florida has a so called inspection that is a total "JOKE" ..The same with the YOM Registration with the original issued Fla Plates..
F.M. is offline   Reply With Quote
Old 12-21-2018, 06:33 PM   #6
Charlie Stephens
A lot depends on where you are coming from. I am from California. I would go with the very faint numbers. Sometimes they can be raised with acid. Do the faint numbers appear to match your current title? Note that in addition to the size there is a special font used and a star at each end. If you are trying to change the number be advised that there are some very strong federal and probably state laws about tampering with VINS. Several years ago California stopped using engine numbers and started issuing VIN tags that they attached to the door jam.
Charlie Stephens
Charlie Stephens is online now   Reply With Quote
Old 12-21-2018, 06:41 PM   #7
woodiewagon46
A company called Resto Stamps makes the unique 1,6,9 and the star.
woodiewagon46 is offline   Reply With Quote
Old 12-21-2018, 07:02 PM   #8
WHN
We have a rebuilt engine in our 1929. Old engine number has been ground off and the frame number for car was re stamped on engine to match all of our paperwork for the last 50 years. Car has been register in N.Y. and Conn. No one has ever question the style of stamping, just confirmed number.
My experience has been that you need confirming back up paperwork. In states like Connecticut titles are not issued to cars over 20 model years old. A Model A would be sold with a bill of sale, and a current or past registration certificate showing VIN.
Engine number should match paperwork. Also, our engine number approval date is June 15, 1929, date on firewall is June 18, 1929. This could all help with DMV person who has questions.
I don’t know if I have helped you. As mentioned earlier, if not a point car, I think you just need to have an engine number that can be read and makes sense to the car it’s on. With back up paperwork. Enjoy.
Old 12-21-2018, 07:27 PM   #9
Paps31
Paps31's Avatar
I donít know if I have helped you. As mentioned earlier, if not a point car, I think you just need to have an engine number that can be read and makes sense to the car itís on. With back up paperwork. Enjoy.
In Kentucky, a vehicle must pass a sheriffís VIN inspection before a title can be issued.
I have the original title, last issued in 1964 in the state of West Virginia with the original serial number. The motor was replaced during restoration between 1964-67.
FWIW, I have the original motor sitting in my shed. It matches the serial number on the title, though itíd take an archaeologist to read it.
The number on the running engine thatís inside the car has about two legible digits, which is just enough to know it doesnít match the title.
Without a matching number INSIDE the car, Kentucky is inclined to issue a salvage title. No thanks.
Since I have two engines, one original, one replacement ó neither of which have legible serial numbers ó but I need matching numbers to obtain a title ... here I am, innocently inquiring about stamp sizes for no particular reason.
Old 12-21-2018, 07:38 PM   #10
WHN
If it was my car, I would make sure numbers matched. Engine number should match paperwork.
You, I don’t believe can get in trouble. You have original engine with the correct P/N VIN.
Have you confirmed frame number? Just a question.
I believe in killing them with paperwork. You can’t question confirming documentation.
Old 12-21-2018, 07:54 PM   #11
Paps31
Paps31's Avatar
You, I donít believe can get in trouble. You have original engine with the correct P/N VIN.
I believe in killing them with paperwork. You canít question confirming documentation.
Yep, thatís the plan. It will all match when I arrive at the inspection station.
I havenít verified the frame number. I imagine itís also not legible and thatís a lot of work for potentially nothing. Perhaps one day Iíll find out. In any case, the frame WILL match the engine number on that day.
Old 12-21-2018, 10:43 PM   #12
Mike V. Florida
Mike V. Florida's Avatar
Did the car have a title when you bought it? If yes then there is no reason to look at it. Same with a modern car, if it has a title then only paperwork needs to be done.
Old 12-21-2018, 11:40 PM   #13
F.M.
Mike, I guess you have never had dealings with the Green Cove Springs Tax office in Fla.. I had it all, Title, old Tags & Reg. Still had to wait for a look see & go back again.. And when they looked at my 1928 A She was lost, would not have know an A engine from a SBC. and said looks fine signed papers and left..
Old 12-22-2018, 09:27 AM   #14
Boston Bruce
Boston Bruce's Avatar
Resto Stamps link here.
Boston Bruce is offline   Reply With Quote
Old 12-22-2018, 10:19 AM   #15
Paps31
Paps31's Avatar
Ordered! A little more expensive than McMaster, but accurate. Thanks, fellas.
I will soon have a ďnumbers matchingĒ car.
Old 12-22-2018, 10:30 AM   #16
1crosscut
1crosscut's Avatar
When you do stamp the numbers use a relatively stout hammer and don't be a sissy about giving them a good thump. It's very difficult to get a stamp set just right for a second try to correct a number that isn't stamped all the way the first time.
Dave
It'll feel better when it quits hurting.
1crosscut is offline   Reply With Quote
Old 12-22-2018, 05:56 PM   #17
F.M.
I agree, But, & its a big BUT, Don't stamp it to close to the top of the block, it will swell the metal and can cause a head gasket leak !!. I have seen this done several times..After stamping run a fine file over the top edge of the block (if possible) to make sure it has not lifted any..
Old 12-22-2018, 06:39 PM   #18
CarlG
CarlG's Avatar
I got my engine stamp set from a guy that listed them here on the Swap Meet. It has all the different fonts plus the star.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
CarlG is online now   Reply With Quote
Old 12-22-2018, 07:18 PM   #19
Chris Haynes
Chris Haynes's Avatar
Despite the fact that altering any manufacturers serial number is a crime and can case you to lose your vehicle and possibly go to prison.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 12-22-2018, 07:37 PM   #20
Charlie Stephens
That is sort of what I was trying to say in Post #6. I like your phrasing better.
GOOGLE "is it illegal to tamper with a VIN". It is sort of like playing the lottery except if you win you lose. I don't play the lottery.
Charlie Stephens
