03-30-2019, 07:36 PM | #1 |
Correct Radiator for 40 Deluxe
Anybody know if the correct 40 car Deluxe radiator has the filler neck on the 45 degree flat or in the center. I see them both ways new but not the angled one in brass, only aluminum. I want to stick with brass but want one an original 40 configuration. Running the flathead.
03-30-2019, 07:51 PM | #2 |
Re: Correct Radiator for 40 Deluxe
The deluxe uses the same radiator as the standard. Contact the Brassworks and he will set up your radiator any way you need it.
03-30-2019, 08:20 PM | #3 |
i have a forty deluxe & mine is on the side it also has a split core
03-31-2019, 07:14 AM | #4 |
I have a 40 Deluxe with a split core, hole for the hand crank and the filler is in the middle on top. It looks original but it could have been replaced 40-50 years ago before I owned the car.
03-31-2019, 07:41 AM | #5 |
My '40 original also has the filler in the middle on top.
03-31-2019, 08:10 AM | #6 |
The only correct radiator for a '40 passenger car, regardless of model, has the filler at an angle and a split core. There will always be "91A" stamped in the top tank. Some time around March, 1940, Ford began outsourcing some of the radiator manufacturing. At that time, the "91A' was stamped in the upper tank as well as other identifying markings that indicated the supplier to Ford. The radiators manufactured by Ford had "B1" stamped in them as well as either the letter "D" (Dearborn plant) or the letter "G" (Green Island plant). Radiators supplied by Modine had "B2" stamped in them and those supplied by McCord, had "B3".
"I can explain it for you. However, I can't understand it for you". Last edited by Kube; 03-31-2019 at 08:23 AM. |
03-31-2019, 09:05 AM | #7 |
Thanks Mike, I never knew what those B numbers meant.
03-31-2019, 09:43 AM | #8 | |
03-31-2019, 10:51 AM | #9 |
The radiator out of my '40 deluxe has the 91A stamping at the right front corner along with L just below. It has the center top fill and crank hole but is not a split core. Aftermarket, dealer replacement or ???
03-31-2019, 01:25 PM | #10 |
Another vote for BrassWorks. Or if you want to save a few bucks, Drake is advertising split core brass radiators for '40 Fords. My guess is that they are off shore but I'm not positive. Photo from Drakes catalogue. If it was up to me I'd go with BrassWorks over Drake but that's JMO.
Making the simple complicated for over 30 years. |
03-31-2019, 02:42 PM | #11 |
Service part...
03-31-2019, 02:46 PM | #12 |
03-31-2019, 02:55 PM | #13 | |
Thread Tools | |
Display Modes | |
