Old 03-24-2019, 08:03 PM   #1
Mulletwagon
Default Grease Fittings
What is the proper way to pump grease through Model A grease fittings ? Are there any direct conversion zerk-type fittings ? If so, are they worth converting to ?
Mulletwagon is offline   Reply With Quote
Old 03-24-2019, 09:00 PM   #2
redmodelt
redmodelt's Avatar
Default Re: Grease Fittings
You just push the gun on the end of the fitting and pump, but you need to have the proper end on the gun. The parts suppliers should all have them.
You can buy a kit with all the modern zerks in it. Some are driven in and some are threaded, so you would need to get the driver and a list of which are which. Most all the jobs we do are drivers so install modern zerks.
redmodelt is online now   Reply With Quote
Old 03-24-2019, 09:27 PM   #3
Clem Clement
Clem Clement's Avatar
jacking may make the spindles easier to grease. I use a air gun.
Old 03-25-2019, 01:05 AM   #4
denniskliesen
denniskliesen's Avatar
The original type were Alemite, todays standard are Lincoln design. This is the gun fitting that Bratton's sells for the original Alemite fittings.
https://www.brattons.com/grease-gun-adapter.html
denniskliesen is offline   Reply With Quote
Old 03-25-2019, 03:01 PM   #5
Mulletwagon
That's the answer ! Thanks Dennis.
Old 03-25-2019, 05:38 PM   #6
whirnot
whirnot's Avatar
I've never had any problem using a standard grease gun. Just hold it on firmly.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
