Old 05-24-2018, 11:14 AM   #21
Big hammer
Default Re: Everyone's Favorite Game: Name That Noise
Originally Posted by ryanheacox View Post
So I tightened up the one nut to match the rest of them, haven't test driven it yet.
New development though. Could it be the timing gear?
https://www.youtube.com/watch?v=rldiSdcjPIM
That noise has been there for a while but it was always much, much quieter.
Slow the idle speed it sounds high, remove your fan belt maybe a bad pulley?
Good luck chasing noises!
get a bigger hammer tap done
Old 05-24-2018, 11:20 AM   #22
ryanheacox
ryanheacox's Avatar
Thanks! Sometimes it's frustrating but chasing noises is all part of the fun.
What would the easiest way be to check the starter bolts. If it were that though I'd think it would get better rather than worse as they self clearance
Old 05-24-2018, 03:27 PM   #23
cliffpatience
Hi,I have not worked on Ford Barn before, but have had an "A" for 53 years.
It "could be" a bad universal joint.
Let me know at cstroncer@verizon.net
cliffpatience is offline   Reply With Quote
Old 05-25-2018, 12:31 AM   #24
Steve Wastler
Steve Wastler's Avatar
Chasing potentially harmful noises isn’t really fun. Try using a section of broom handle, long screw driver or pry bar, or my favorite a mechanics stethoscope from harbor freight to help isolate area of concern from rest of vehicle, sound transmission will change in relationship to where you stand with naked ear. Too much background engine noise and too short of video to guess as to origination point.
Steve Wastler is offline   Reply With Quote
Old 05-25-2018, 08:44 AM   #25
ryanheacox
ryanheacox's Avatar
Bad U joint has crossed my mind as well. I'll have to look into it further.
I'll use a broom handle the next time it makes noise while idling, I just hate how random it is.
Old 05-26-2018, 07:53 AM   #26
burner31
burner31's Avatar
I find the older I get the less strange noises come from my car...not sure if my hearing is getting worse or my car is running better?
Keith
Shawnee OK
'31 SW 160-B
Old 05-27-2018, 09:00 AM   #27
Gary WA
Gary WA's Avatar
Throw out bearing?Lube it or pilot bearing.
www.whidbeymodelaclub.com
Old 05-27-2018, 12:00 PM   #28
Osage Orange
Check the pressure plate fingers again. If you haven't backed off the starter bolts, pull each out, one at a time, and put two flat washers in to shim for each bolt.
Osage Orange is offline   Reply With Quote
Old 05-29-2018, 07:21 AM   #29
ryanheacox
ryanheacox's Avatar
Will do, I'll shim the starter bolts today and recheck the pressure plate. Thanks for the advice everybody.
Old 05-29-2018, 07:33 AM   #30
ryanheacox
ryanheacox's Avatar
Also, what size are the starter bolts? I can grab some washers at work
Old 05-29-2018, 12:05 PM   #31
100IH
I'd take one out and stick it in my pocket. And in the process, look at the tip of the threaded end for signs of rubbing on the flywheel. The length is supposed to be 1"".
100IH is offline   Reply With Quote
