Old 02-14-2019, 12:28 PM   #1
Steve Plucker
Default Special electrical charger needed...
Where may I find a charger that I can regulate the Voltage and Amprage?
Looking for something that will give me at least 2-3 Volts and 2-3 Amps.
So far Harbor Fright, Grainger, and NAPA can not help.
Been trying the internet but with no luck.
Thanks.
Pluck
Old 02-14-2019, 12:43 PM   #2
nhusa
nhusa's Avatar
Default Re: Special electrical charger needed...
Check Amazon -
I got a great solid state 6 volt to 12 volt convertor so I could us 12 V LED stop lights on my Model A. Since the A was positive ground all I needed to do was make sure the wiring was correct for the LEDs.
nhusa is offline   Reply With Quote
Old 02-14-2019, 01:15 PM   #3
ryanheacox
ryanheacox's Avatar
A laboratory power supply might do what you want. https://www.jameco.com/z/LABPS3003SM...D_2245503.html
Old 02-14-2019, 01:27 PM   #4
30 Closed Cab PU
x2, I agree.. You are looking for a variable voltage power supply with separate.variable current liming. I have not seen a battery charger that has both of these features.
Perhaps EBay, swap meets, or some other place that sells used equipment. Look under DC power supplies, or variable DC power supplies.
Old 02-14-2019, 01:34 PM   #5
GPierce
GPierce's Avatar
Google variable voltage power supply.
https://flash.newegg.com/Product/9SI...E&gclsrc=aw.ds
GPierce is offline   Reply With Quote
Old 02-14-2019, 03:30 PM   #6
jbond
Caswell.com has a power supply for plating.
https://www.caswellplating.com/elect...-supplies.html
jbond is offline   Reply With Quote
Old 02-14-2019, 10:10 PM   #7
Pete
Pete's Avatar
Try this on eBay.
#222410060720
Old 02-14-2019, 10:26 PM   #8
Smooth_One
Smooth_One's Avatar
I use one of these on my car. I know it’s just a tender but it works great and it auto detects between 6V and 12V.
Isaiah B.
1928 all metal Tudor
Smooth_One is offline   Reply With Quote
Old 02-15-2019, 06:35 AM   #9
Steve Plucker
Thank you guys...a variable voltage power supply is what I needed.
Hope it works.
Pluck
