08-16-2018, 07:03 AM | #1 |
35 Universal Joint Grease Cup Hole
I need info about the inner grease cup. The grease fitting for the universal joint
is located around 5 o"clock on the passenger side. The inner cup I would like to use has 2 holes in it. One of them is located very close to the fitting location and the other is at about 11 o"clock. Is the cup I have correct for my 35 application or do I need to find a cup that only has the one hole located near the fitting? |
08-16-2018, 07:20 AM | #2 |
Re: 35 Universal Joint Grease Cup Hole
Peter,
What you have will work just fine. |
08-16-2018, 08:55 AM | #3 |
DavidG is correct. I added a grease fitting for that 11 o,clock hole so I could grease the universal from inside the car. Probably overkill as universal joint isn't greased that often.
08-16-2018, 09:06 AM | #4 |
Thanks men for you timely responses.
Peter |
08-16-2018, 12:11 PM | #5 |
Thread Tools | |
Display Modes | |
