03-23-2005, 01:47 PM | #1 |
Guest
Posts: n/a
Re: 97 on a 49-53 engine- vac where?
Very good debate gentleman! So, to conclude, do you think that the 97 base with a vac will work or not? I don't see how because I would be like Doby said- manifold vac. which is different than what come out of a 94...... |
03-23-2005, 04:14 PM | #2 |
Guest
Posts: n/a
The carb may do its job of delivering fuel and air to the combustion chambers just fine, but the distributor advance won't work right. I suppose you could put weaker advance springs in the distributor, but you'd have to play around with various springs to get it right. This isn't an easy job with a Loadamatic distributor. The advance springs are not easy to get to. |
03-24-2005, 12:31 AM | #3 |
Guest
Posts: n/a
Re: 97 on a 49-53 engine- vac where?/ FHY
ok i guess it wont work doby ill take your word for it. ken ct. did you or anybody ever try this in the past to see if it worked.?? now im courious to try it. flat head youngen. if you want to try it ill send it to you if dont work send it back to me. ken ct. call me if you want, 1-203-375-9340 |
