06-25-2019, 03:34 PM | #1 |
1936 Pickup running hot!
Hey guys, I am working on trying to finish up my '36 this summer! I have the engine in and running, it was a "Fresh" rebuild from about 20 years ago. It starts right up and runs very smooth, BUT it does run a little hot... I know that sometimes they will run a little hot after first start up while everything breaks in. The temp gauge will rise continuously until I finally shut off the engine. I took temperatures with a digital temp gun to make sure that the gauge isn't off... The highest that I got were readings around 180-190 all over the heads and the hoses as well, there were a couple of hot spots that reached 200-205, this seems hot to me. It has no thermostats in the hoses, the water pumps are the newer sealed bearing type, and I am running a 50/50 mixture of water and anti freeze. I know that this topic has been discussed to death, but I am looking for any help to try and get this truck to run cooler! Any help/ideas are certainly appreciated!!
06-25-2019, 03:44 PM | #2 |
Re: 1936 Pickup running hot!
Nice truck!!! Is this temp measured with the engine running stationary? Driving it down the road is a better test than stationary in your garage....
06-25-2019, 04:00 PM | #3 |
I had the engine in my O/T Corvette rebuilt about 15 years ago. It ran hot (just like yours) from the start. I could run around town and down the highway just fine, but let it idle more than a couple of minutes, and the temp gauge would start to rise...and rise...and rise. After about 800 miles of this, when I was just starting to think about pulling it and taking it back to the machine shop, it quit running hot. I think it was built "too tight" and had to wear in.
Bottom line, i would get it on the road and drive it. If it diesn't run hot driving around, it'll probably break in and be fine. Also, make sure your timing is right. |
06-25-2019, 04:09 PM | #4 |
Timing retarded will contribute to overheat. With modern gas you can advance the timing. First check the vacuum brake on the distributor to be sure it has a little pressure with no vacuum, then use the adjustment on the side of the distributor to advance the spark. I would go full advance and then check it under load for pinging. If it pings, back off on the advance until it does not ping.
06-25-2019, 06:17 PM | #5 |
Thanks for the replies! Yes, I am measuring stationary in my shop.. I did put 2 fans in front of it to try and simulate some air movement around the engine to try and help. I had the distributor and coil rebuilt at Bubba's, I didn't move any of the vacuum or timing since I got it back, I just bolted it on and runs smooth so I figured I was good. What is the best way to check my timing on this?? Thanks again!
06-25-2019, 06:32 PM | #6 |
06-25-2019, 06:45 PM | #7 |
Theres nothing wrong with those temps, put 180 thermostats in. Cast iron should be running 180+ . 200 might be slightly high BUT hotter the better so long as it doesn't boil over..
Put temperature gauges in one in each head, dont be surprised if they are slightly different when running ..
"Came too close to dying to stop living now!" |
06-25-2019, 07:58 PM | #8 |
What Talkwrench said! And the engine would be a lot better off running it with a load on it until it is broken in. The rings will set better if it is driven, stationary running is not the best idea.
06-25-2019, 08:06 PM | #9 | |
Did you mean to say "run with a load"
06-25-2019, 08:08 PM | #10 |
Oops! Repetitive post removed....
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 06-25-2019 at 08:17 PM. |
06-25-2019, 08:12 PM | #11 |
Yes, Pete, I did. I have corrected that sentence 4 times now! I'm really having a difficult time being coherent today, LOL!!!
06-25-2019, 08:36 PM | #12 |
Yeah how many times have I seen on Faceblah , guys that have videos of "first startup of my flathead " on engine stands and they let it idle.. give it a few revs and let it sit and idle away PFfT! ..
Get it in give it some..
06-25-2019, 10:35 PM | #13 |
What is the condition of the radiator? A clean one flows more water and cools better.
06-26-2019, 12:17 AM | #14 |
06-26-2019, 07:34 AM | #15 |
I have run 100's of heat tests in Florida on 90 degree or
warmer days. I use a 24" Lasko square box fan sitting on the bumper and laying against the bottom of the grill. With the fan on high, the radiator FILLED up in the filler neck, plain water, 2 bottles of Purple Ice and 1 gallon of Prestone perminate and a large bottle of Barr's stop leak, the type with copper flakes. You need a 2 lb pressure cap or a tight sealing early type cap. In order to get the early caps to seal you need the drill the rivet out, cut a round flat gasket out of the thin red rubber gasket material found in the plumbing section of your local hardware store. Replace the rivet with a stainless steel slotted 1/4 x 20 screw.3/4" long with lock washer and nut, put a little lock-tite on the threads. Run the engine at a speed equal to about 20 MPH. If coolant come out the over flow make sure you don't have a compression leak. After running for an hour or more shut the engine down, DON"T remove cap and let sit over night, the slight pressure in the system will force the stop leak into any small pin hole leaks and seal them. The temp in this test should not get over 195. Temp in these old Ford engines is controlled by The amount of coolant in the system and the gallons of coolant pumped through the system every 5 minutes. Don't believe the story that the coolant is going through the engine to fast. Modern and reproduction pumps move 55 to 65 gallons off coolant through the engine every 5 minutes, Skips modified pumps move 110 gallons every 5 minutes. The cooling effect can be measured with a laser pointed temperature gun at the bottom and about 4"s from the top of the radiator. We also notice on the water pump test machine which is a sealed closed circuit the same as the radiator that after a 5 minute test run of a pump that when the cap is released there is very little air in the system compared to a stock pump. This is due to the fact the impeller and it's tight controlled clearance with the seat is pushing water and not slipping in water making air. When the cap is released with a stock pump there is a gush of air and on Skips pumps there is hardly any air. A clean block, heads and radiator are required for good heat transfer. This is not intended to be an add for Skip, just the true facts found after over 20 years of rebuilding Ford pumps. Read the results posted of people using Skips pumps and they tell the real story. G.M.
www.fordcollector.com |
06-26-2019, 07:52 AM | #16 |
Thanks, I have had the radiator cleaned and re cored so that shouldn't be a problem. I have thought about sending my pumps down to skip to have them rebuilt just because I have read that his are the best. I have looked, but cannot find thermostats that will fit in this engine, what is everyone else using for this? Or am I better just leaving without thermostats? Also, what are you guys using for temp gauges?? I am thinking it would be nice to have a gauge with actual temp readings on it. Thanks again for all your help! Keep it coming!!
06-26-2019, 12:24 PM | #17 | |
where the gauges read. The best thing is to run with no thermostats until you see the temperatures, stats don't help with cooling, just make the engine run hotter. The best thermostats fit into the upper radiator hoses. Bob Shewman in Kimberton, Pa. make stats that fit in the hoses. Bobs phone number is 1-610-933-6637 Beware of stats with small flow opening, these restrict the flow of coolant through the engine. G.M.
www.fordcollector.com Last edited by G.M.; 06-26-2019 at 12:31 PM. |
