06-13-2019, 02:19 PM | #1 |
Open driveline to 6 spline pinion
Is there a Ford U Joint flange for a driveshaft that fits the Ford Banjo 6 spline pinion ? I see the 42-47 commercial axle in the Green bible has a tapered pinion with key. Thank you Fordbarners.
06-13-2019, 02:57 PM | #2 | |
Re: Open driveline to 6 spline pinion
Unfortunately theres no Ford flange made to match up to the Ford banjo six spline pinion. A pricey conversion is made to do it sold by Speedway the parts a probably off shore quality. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
06-13-2019, 03:58 PM | #3 |
Thank you.
06-13-2019, 07:09 PM | #4 |
I think Hot Rod works sells an adapter to convert to open driveline. Would be good quality.
John
Welcome each day |
06-13-2019, 07:33 PM | #5 |
Yes HRW does a quality product.
https://www.hotrodworks.com/product-...e-conversions/ |
06-13-2019, 11:16 PM | #6 |
06-14-2019, 03:20 PM | #7 |
Anyone have any luck finding a stock 6 spline Spicer u joint flange from some application. The rest of the stuff is available.
