Old 01-18-2019, 03:45 PM   #21
JSeery
JSeery's Avatar
Default Re: Dark brown gravy for oil
They have been posted several times recently.
Old 01-18-2019, 04:56 PM   #22
AnthonyG
AnthonyG's Avatar
JS do u have one u think is best?
Nomad
AnthonyG is offline   Reply With Quote
Old 01-18-2019, 05:28 PM   #23
flatjack9
flatjack9's Avatar
I use Stant 45358 thermostats - 180 deg
Old 01-18-2019, 06:16 PM   #24
JSeery
JSeery's Avatar
Not really.
Old 01-18-2019, 06:40 PM   #25
grumppyoldman
grumppyoldman's Avatar
Sounds like anti-freeze in oil to me, seen it before. Al
grumppyoldman is offline   Reply With Quote
Old 01-18-2019, 09:23 PM   #26
AnthonyG
AnthonyG's Avatar
Thx flatjack9, Amazons amazing, can't believe how much stuff u can get. Seems like almost anything, got 2 of the Stant 45358 thermostats - 180 deg for under $14 delivered.
Nomad
Old 01-18-2019, 09:24 PM   #27
AnthonyG
AnthonyG's Avatar
Thx JS too
Nomad
Old 01-18-2019, 09:49 PM   #28
40 Deluxe
Originally Posted by flatheadmurre View Post
Short trips when engine donīt get up to full working temp for an extended period can give you condensation with sludge as result...so before fearing the worst change oil and take it for a long nice drive.
I see this alot on modern cars to that just drives 10min to the mall and back.
The 8BA road draft tube crankcase ventilation system was a big improvement over older flatheads, but was still ineffective at low speeds and worthless sitting in the driveway "warming up"!
You need a good run at 50-60 MPH (or more) to get airflow past the end of the tube to pull crankcase fumes out while drawing fresh air in through the breather cap on the intake manifold. That's why it was called a "road draft tube"; you needed to go fast enough to get a "draft" going at the end of the tube.
This is just one reason a PCV system is so much better. It ventilates the crankcase even idling in the driveway!
Old 01-18-2019, 10:00 PM   #29
Tinker
Tinker's Avatar
Seems weird that we are talking about Subaru temps (granted it was current discussion lately)..... when it seems like you have choco oil.
Change the oil, see how fast you have coolant in the oil... It'd take a long time for condensation to make your oil into Chocolate milk.
Gas will just thin the oil. Not change the color.
Old 01-19-2019, 07:53 AM   #30
chap52
chap52's Avatar
If you get the oil figured out and still want to add stuff to the radiator I always had good luck using "Alumaseal". You can get it on Amazon, but a lot cheaper at Wal Mart. Chap
https://www.walmart.com/ip/ALUMASEAL...54de9732f23fe4
Old 01-19-2019, 09:42 AM   #31
JSeery
JSeery's Avatar
Thx JS too
The numbers I posted are NOT correct for a 8ba engine! Those are 59a numbers.
Old 01-19-2019, 10:47 AM   #32
AnthonyG
AnthonyG's Avatar
JS Do u know the correct ones 4 the 8ba?
Nomad
Old 01-19-2019, 11:50 AM   #33
AnthonyG
AnthonyG's Avatar
Checked Stant listings 13358 or 45358 both fit 8BA so I’ll have a couple as back ups.
Nomad
Old 01-19-2019, 01:01 PM   #34
JSeery
JSeery's Avatar
Yep, the 8ba is easier to ID as they had modern style thermostats from the get-go. Sorry about the 59a post, had a computer HD failure and wasn't paying attention!
Old 01-25-2019, 10:53 AM   #35
AnthonyG
AnthonyG's Avatar
Question: I'm Getting ready to change oil, run aluminum powder into cooling syst., & install stats., will the aluminum powder fowl the stats?
Nomad
Old 01-25-2019, 11:04 AM   #36
JSeery
JSeery's Avatar
No.
Old 01-25-2019, 11:43 AM   #37
AnthonyG
AnthonyG's Avatar
Thx J
Nomad
Old 01-25-2019, 04:04 PM   #38
AnthonyG
AnthonyG's Avatar
Oil changed, put stats in, put aluminum powder product in. Ran per instructions on aluminum powder sealer. Cooling over nite. Will test drive take long ride tomorrow and see if cured.
Nomad
Old 01-26-2019, 03:09 PM   #39
AnthonyG
AnthonyG's Avatar
Took a 1.5 hour drive today, kept the temp at 175 to 190, no sign of white smoke or bubbling in radiator. checked oil a few times stayed a nice light brown clear honey color. Problem seems solved but will check oil frequently.
Thx for tips & ideas.
Nomad
