05-26-2011, 11:43 AM | #1 |
If you have a muffler heat shield...
If you have a muffler heat shield and you suddenly notice a new rattle, you may find the same thing that I did. On mine the bracket broke the the bend--the top of the bracket is still riveted to the shield and the bottom is still bolted to the muffler, but the metal gave way where the bend is in the bracket.
I guess this is a good weekend to run out and pick up a welding rig Last edited by dan; 05-26-2011 at 11:49 AM. |
05-26-2011, 12:10 PM | #2 |
Re: If you have a muffler heat shield...
Dan,
It looks like a lot of space between the two. Could it be there was stress to pull apart like that, or is the picture an optical illusion? GW |
05-26-2011, 12:53 PM | #3 |
Looks like the clamp just vibrated away from the shield.
I'm actually about to purchase a heat shield. Do you like it? Do you notice a cooler passenger compartment?
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
05-26-2011, 12:59 PM | #4 |
Mine broke and Ihad to rerivet it. Vibration plus heat plus tighening it too tight caused the failure.
My Model a is significantly cooler with the shield. I also have a sheet of the silver insulation material on the fire wall and the floor. Here is the real secret: If Momma is to ride with you, freeze up some water bottles. Lay them on the floor so Momma can rest her bare tooties on the cold bottles. Happyness is. |
05-26-2011, 02:02 PM | #5 |
I believe that this is why we're supposed to buy the more expensive model by Leslie Pam, rather than the cheaper product most suppliers sell.
05-26-2011, 02:42 PM | #6 |
$79.95 model....
05-26-2011, 03:59 PM | #7 | ||
------- Quote:
------- And I would recommend one of these to folks where the summers are warm. In the summer it made a big difference in how hot it got inside the car here in California. |
05-26-2011, 04:34 PM | #8 |
We did a review, in the Model A Times, of the Pam shield vs the other item found much better results in the heat shield, and it is built stronger.
05-26-2011, 05:58 PM | #9 | |
Reminds me of an old H.P.Lovecraft horror story, Cool Air. Anybody remember Dr. Munoz? The Short story was published during the Model A era, in the March 1928 issue of Tales of Magic and Mystery. In 1971 the TV show Night Gallery also did a production of it. You gotta keep cool, keep that ammonia machine running! |
