01-16-2015, 11:32 AM | #1 |
Oil
Is there a way for a simpleton to tell the difference between detergent and non-detergent oil? Would like to know what is now in my A. Thank you, Nick
01-16-2015, 11:58 AM | #2 |
Re: Oil
I don't know of any way to tell unless you send in a sample for analysis. I would just start using detergent no matter what the car had before. If the engine has sludge, it needs to be cleaned out.
01-16-2015, 12:10 PM | #3 |
Re: Oil
Was reading (on MAFCA site) that engine will start to burn more oil and valve problems could occur if changing from non-detergent to detergent? Sure don't need engine issues, so thought it might be best to continue to use what is in there now (but don't know what was being used). With my limited skills little hesitant to drop the oil pan and deal with oil pump, gasket and creating more problems for myself.
01-16-2015, 01:03 PM | #4 |
Re: Oil
With the very limited Model A engine information given, just one suggestion from past Model A experiences:
1. First Simple Test: If you unscrew the oil pan drain plug & nothing comes out, chances are 99.99 to 1 you have non-detergent oil sediment sludge on the bottom of the oil pan blocking oil flow. 2. Secondly, even if oil does comes out, with an unknown 80+ year old engine, plus past experiences of listening to former Model A owner's idea of what constitutes a clean Model A engine, in "any" & "all" cases, I would drop the oil pan & remove the side valve chamber cover to see if they need cleaning. 3. Third, clean if needed and provide fresh detergent oil. 4. Fourth, just get out and drive as many miles as you would like in peace without fear of creating a mosquito killing oil burning Model A smoker that many of us witnessed in the late 1940's & early 1950's. Hope this helps to quell your engine lubrication concerns in a positive manner. |
01-17-2015, 01:42 AM | #5 |
Re: Oil
Once it leaves the bottle there is no way to know.
01-17-2015, 08:43 AM | #6 |
Re: Oil
Terry |
01-17-2015, 10:58 PM | #7 |
Re: Oil
Thank you guys. I think I will just open the drain a see what comes out as H. L. Chauvin suggested. If it "flows" out I may be alright, if not I guess it's time to drop the pan.
01-18-2015, 12:41 AM | #8 |
Re: Oil
If you don't know the history, drop the pan. It can be done with engine in car.
Thread Tools | |
Display Modes | |
